LPC2378 No USB_EVT_OUT
Gent;
I'm apologize for repeating a question that appeared to be answered in thread11137. It seems Doug and Tsuneo were trouble shooting a USB interrupt out problem. I'm having the same problem. No USB_EVT_OUT.
I'm at the exact same point where Doug was on Feb 20.
I do not see a resolution to Doug's effort on this or later threads.
I am able to send 64 byte InReports with no problems.
This is a copy of my URB from the HHD snooper software.
000173: Bulk or Interrupt Transfer (DOWN), 28.03.2008 18:06:13.625 +0.0
Pipe Handle: 0x8924ed4c (Endpoint Address: 0x81)
Get 0x40 bytes from the device
000174: Bulk or Interrupt Transfer (UP), 28.03.2008 18:06:13.656 +0.031. Status: 0x00000000
 01 55 AA FF 00 00 00 00 00 00 00 00 00 00 00 00   .Uªÿ............
 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ................
 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 AF   ..............ð¯
This is repeated at the specified 32 milliseconds.
At the same time in my Host App, I have a forever loop calling WriteFile to write 8 bytes. I do not see any out packets other than the control packets to request an InReport.
Using the original Keil example, I can see Up/Down packets but the Down packets appear to be Control Transfers.
This code is a stripped version from John Hyde's BALVC code from his book.
unsigned long BytesWritten, BytesRead;
UCHAR OutReport[8] = {2,3,5,4};
case 'l':
   printf("\nValue to be written to Dig_Out: ");
   while(1){   // For test only - Remove!!!!!!!
     for(i=0; i<10000; i++);  // just a delay
     Result =  (WriteFile(Handle, OutReport,
          sizeof(OutReport),&BytesWritten, NULL));
     if (Result == FALSE)
         printf("\nError writing to I/O device\n");
   break;
case 'e':
I'm using VS 2005. Setting a breakpoint at the line if(Results.....
I can look at OutReport buffer and the hard coded values appear correct. BytesWritten is 0. The Handle value is the same as the Handle value for the ReadFile operation which works fine. Results == FALSE.
The descriptor configs look correct to me but I include them also. They were captured via USBView.
I edited the VendorID and ProductID. NDA and all that stuff.
I guess I'm asking how to proceed from this point to determine if the problem is in the Host app which is stripped to a bare minimum or in the device program which works fine with InReports in interrupt transfers and OutReports in Control transfers but not interrupt transfers.
Yes, one other thing. My manufacterID, etc., strings appear in the String buffer transmitted as Unicode.
Is this the defalut for USB? Is there a software switch to enable/disable? Can this be part of my problem?
My Keil Software is MDK full Version 3.20. My JTAG is Ulink2.
Device Descriptor:
bcdUSB:             0x0110
bDeviceClass:         0x00
bDeviceSubClass:      0x00
bDeviceProtocol:      0x00
bMaxPacketSize0:      0x40 (64)
idVendor:           0xXXXX
idProduct:          0xXXXX
bcdDevice:          0x0100
iManufacturer:        0x04
iProduct:             0x20
iSerialNumber:        0x42
bNumConfigurations:   0x01
ConnectionStatus: DeviceConnected
Current Config Value: 0x01
Device Bus Speed:     Full
Device Address:       0x02
Open Pipes:              2
Endpoint Descriptor:
bEndpointAddress:     0x81  IN
Transfer Type:   Interrupt
wMaxPacketSize:     0x0040 (64)
bInterval:            0x00
bEndpointAddress:     0x01  OUT
bInterval:            0x20
  • "At the same time in my Host App, I have a forever loop calling WriteFile to write 8 bytes. I do not see any out packets other than the control packets to request an InReport."
    Then, it is the problem on the host app side.
    a) Report Descriptor on the firmware
    Did you declare exactly 8 bytes Output report on the Report Descriptor?
    The HID device driver on the PC reads out the Report Descriptor, and check the ReadFile parameters according to the descriptor.
    - Search "Descriptor work" on the thread11137
    http://www.keil.com/forum/docs/thread11137.asp
    b) On the host app,
    What is the size of OutReport?
    - To send 8 bytes, sizeof( OutReport ) must be 9.
    The first byte of OutReport array is the report ID.
    If you don't declare any report ID on the Report Descriptor, the default report ID, 0, is applied.
    OutReport[ 0 ] = 0; // report ID
    The index 1..8 of the array hold the actual report.
    Tsuneo
  • Tsuneo:
    b) On the host app,
    This was indeed my problem. I could not see the forest for the trees. Thank you VERY much for your help.
    Bradford
  • On the subject of HID In/Out reports, can anyone tell me whether the size is fixed (as per the Report Descriptor) or can it be regarded as a maximum ?
    i.e. If the descriptor specifies In/Out report sizes of 16 bytes, is it permissible to send smaller reports, in either direction, or must I ALWAYS send the full 16 bytes ?
  • The report size (number of bytes) is always fixed to the size (count) declared on the Report descriptor. HID device driver on PC doesn't accept any report of different size, either for Input or Output.
    Using report ID, you can declare reports of different size on single Report descriptor.
    #define INREPORT_SIZE1    64
    #define OUTREPORT_SIZE1   64
    #define INREPORT_SIZE2    1024
    #define OUTREPORT_SIZE2   1024
    #define HID_ReportCountS(x)     0x96,x
    /* HID Report Descriptor */
    const BYTE HID_ReportDescriptor[] = {
      HID_UsagePageVendor( 0x00                                   ),
      HID_Usage(           0x01                                   ),
      HID_Collection(      HID_Application                        ),
        HID_LogicalMin(    0                                      ),
        HID_LogicalMaxS(   0xFF                                   ),
        HID_ReportSize(    8                                      ),  // bits
      // Report ID 1
        HID_ReportID(      1                                      );
        HID_ReportCount(   INREPORT_SIZE1                         ),  // bytes
        HID_Usage(         0x01                                   ),
        HID_Input(         HID_Data | HID_Variable | HID_Absolute ),
        HID_ReportCount(   OUTREPORT_SIZE1                        ),  // bytes
        HID_Usage(         0x01                                   ),
        HID_Output(        HID_Data | HID_Variable | HID_Absolute ),
      // Report ID 2
        HID_ReportID(      2                                      );
        HID_ReportCountS(  INREPORT_SIZE2                         ),  // bytes
        HID_Usage(         0x01                                   ),
        HID_ReportCountS(  OUTREPORT_SIZE2                        ),  // bytes
        HID_Usage(         0x01                                   ),
      HID_EndCollection,
    There are several troublesome rules about report ID.
    1) Default report ID
    On the Windows host app, The reports always starts with the report ID. When no report ID is used in the Report descriptor, the default ID, 0, is applied.
    On the other hand, the firmware doesn't need to add report ID, just when no report ID is used in the Report descriptor. If any report ID on the Report descriptor, the firmware also adds the report ID at the top of the report.
    2) The buffer and its size on Windows
    On the Windows host app, ReadFile and WriteFile always expect the longest buffer and transfer size, regardless of the actual report.
    The buffer size is retrieved in HIDP_CAPS using HidP_GetCaps().
    PHIDP_PREPARSED_DATA    preparsedData;
    HIDP_CAPS               capabilities;
    HidD_GetPreparsedData( deviceHandle, &preparsedData );
    HidP_GetCaps( preparsedData, &capabilities );
    HidD_FreePreparsedData( preparsedData );
    DWORD nNumberOfBytesToRead = capabilities.InputReportByteLength;
    ReadFile(..., nNumberOfBytesToRead, ...);
    DWORD nNumberOfBytesToWrite = capabilities.OutputReportByteLength;
    WriteFile(..., nNumberOfBytesToWrite,...);
    The report of greater size than wMaxPacketSize of the endpoint, is split into multiple packets of wMaxPacketSize size. The last packet has short size.
    I recommend you to keep less than 4 KBytes for report size, which is the page size of PCI memory.
    Tsuneo
  • Thank-you Tsuneo - that is very helpful.
    Based on my undestanding of what you say, it should be possible to define a report descriptor containing all possible report sizes from 1 to 16, with associated ReportIDs from 1 to 16. The (variable-sized) report then sent by the firmware could simply include the (variable) size as the ReportID. I may have to subtract 1 as ReportID starts from 0.
    Do you know of any reason why this would not work ?
    Do ReportIDs have to be assigned sequentially ?
    i.e. If (using the scheme above) I only wanted to send reports of size 4, 8, 12 and 16, could I assign ReportIDs of 4, 8, 12 and 16 or would I have to use 0, 1, 2 & 3 (or 1, 2, 3 & 4) ?
    Our testing to date (only with full-speed USB) suggests that Windows XP only has a 64 byte buffer for received HID reports. Using smaller HID reports, where possible, may allow us to queue more reports without Windows throwing the oldest ones away.
  • Bug fix:
    [ ERROR ]
    [ Revised ]
    #define HID_ReportCountS(x)     0x96,(x&0xFF),((x>>8)&0xFF)
    Tsuneo
  • "I may have to subtract 1 as ReportID starts from 0."
    Report ID zero is reserved and should not be used.
    "Do ReportIDs have to be assigned sequentially ?"
    No need to be sequential.
    "Our testing to date (only with full-speed USB) suggests that Windows XP only has a 64 byte buffer for received HID reports."
    WinXP actually support reports of more than 64 bytes.
    How do you send the report?
    You have to send two or more split packets to sends the entire report.
    For example, when you send 100 bytes report with report ID 100,
    the size of the report goes to 101 bytes (report ID + the body of the report).
    Then, the first packet counts 64 bytes, (report ID + the first 63 bytes of the report),
    And, the second packet is 37 bytes, (the last 37 bytes of the report).
    Tsuneo
  • Yes, I understand that 64 bytes is only the frame size limit (on full-speed), and not the report size limit.
    However, it doesn't seem possible to read more than 64 bytes at once under Windows XP. Attempting to read more only ever returns a maximum of 64.
    On one of our products, with a report size of 8 bytes, our reports can be bursty. We have seen instances where Windows XP appears to throw away the oldest reports, buffering only the last 64 bytes received. Increasing the report size would obviously make this problem more likely. As not all of our reports on this product actually need to be 8 bytes, we had thought to send variable size reports, thus making maximum use of Windows' limited buffering.
    Another alternative is obviously to read from Windows more frequently.
    Tsuneo, do you have any comments on the proposal I made (in my previous post) to define a Report Descriptor including all possible report sizes ?
    Thanks,
    David.
  • "However, it doesn't seem possible to read more than 64 bytes at once under Windows XP."
    On the device side, the report of greater than wMaxPacketSize is split into packets.
    On the host app, however, the report is handled at a time using single ReadFile or WriteFile call. How do you call ReadFile or WriteFile?
    "We have seen instances where Windows XP appears to throw away the oldest reports, buffering only the last 64 bytes received...Another alternative is obviously to read from Windows more frequently."
    The built-in HID device driver has a cyclic buffer for input reports. It holds up to 32 reports as the default for WinXP. (See HidD_SetNumInputBuffers reference)
    Windows starts interrupt-IN transactions to HID devices just after the device is plugged-in and enumerated. Please note, these transactions occur regardless of the host application. Until the host application starts, the reports sent by your device are discarded. When your host application starts and open the HID device using CreateFile, the input-report buffer is also allocated and starts to be filled with the reports from the device. If it takes for a while to issue ReadFile after CreateFile, the input-report buffer may have been already filled with the old reports. If your application don't have any interest to these old reports, flush the buffer using HidD_FlushQueue().
    If your device firmware puts the input reports every time when the interrupt occurs at the interrupt-IN endpoint (as the KEIL example does), the input reports are generated at the rate defined in the bInterval field (ms) of the endpoint descriptor (actually, at the nearest number of power of 2, less than or equal to bInterval, ie. 1, 2, 4, 8, 16, 32, ...).
    As you have experienced buffer overflow on the input-report buffer, there are three solutions for this problem.
    a) Send reports just when your device desires.
    b) Read multiple reports on the buffer at a time.
    c) Increase the bInterval to reduce the rate of the input report.
    d) Read out the buffer more frequently.
    c) and d) are obvious, and trivial solution.
    To implement a) solution to your device, you have to handle the interrupt-IN endpoint out of the interrupt handler of the endpoint. The interrupt of this endpoint is triggered just when the host reads out the data on the endpoint. That is, this interrupt is initiated by the host side, host event. In most cases, however, you are interested in the event caused on the device side as the trigger of the report. For example, USB mice and keyboards send their reports, just when the devices detect user's action. To send a report just when the device wants, the reports are filled to the endpoint at the main loop task, or the interrupt task other than the endpoint, such as timer interrupt. See this topic for details.
    "HID Mouse keeps sending unneeded data!"
    http://www.keil.com/forum/docs/thread11531.asp
    b) You can read out multiple reports on buffer using single ReadFile call.
    Call ReadFile with greater buffer and greater nNumberOfBytesToRead.
    nNumberOfBytesToRead = (report size plus one (for report ID)) x n;
    n: number of reports you want to read out.
    ReadFile returns the number of bytes read actually, in lpNumberOfBytesRead.
    Using HidD_SetNumInputBuffers(), you can tune the numbers of reports held in the buffer.
    "do you have any comments on the proposal I made (in my previous post) to define a Report Descriptor including all possible report sizes ?"
    It's possible, and some devices actually implements this scheme (for example, SiLabs USB debug adapter).
    But I don't think it makes so much difference from following scheme,
    - Declare single report with the greatest size required (plus one).
    - Place the actual number of bytes of the report at the first byte
    - Fill variable-length body after the length byte (like Pascal style string)
    - Padding the rest.
    [References]
    msdn2.microsoft.com/.../ms790946.aspx
    HidD_FlushQueue()
    msdn2.microsoft.com/.../ms790918.aspx
    Tsuneo
  • Thank-you again Tuneo for your time and detailed reply - it is very much appreciated.
    Let me try to address some of the points you make :-
    Our wMaxPacketSize is typically only 8 or 16, the same size as our maximum HID report, so we have no need to split reports into multiple frames.
    Our host app calls ReadFile() something like the following :-
    ReadFile(handle, buffer, sizeof(buffer), &numBytes, pHIDOverlapped);
    Result = WaitForSingleObject(pHIDOverlapped, 100);
    if (Result == WAIT_OBJECT_O)
      GetOverlappedResult(hande, pHIDOverlapped,, &numBytes, FALSE);
    else
      CancelIo(handle);
    buffer size is currently (65 * 8).
    Our firmware only sends reports when it actually has something new to report (unlike, as you say, the Keil example). However, the nature of those reports is asynchronous and sometimes it has to send multiple reports in a short period of time.
    To determine if reports were being lost, we modified the firmware so that, on demand, it sent 20 x 8-byte reports in a short time, each containing an incrementing value. When the host app reads these reports it only ever gets a maximum of 64 bytes (the last 8 frames) with older ones having been thrown away.
    Regarding your four options :-
    We already do (a) and (b). We could do (c) but this would obviously increase the latency of the device, which is not desirable. (d) is the option I referred to in my last post, but Windows is notoriously unpredictable when it come to trying to do something very quickly very regularly - it's not exactly designed for real-time.
    Your suggestion to pad reports to the defined maximum size is exactly what we currently do. However, because of the problem with Windows apparently dropping reports under load, we are interested in being able to send smaller reports where possible.
    ...breaking news...
    Our host app programmer has just reported that your suggestion of increasing the number of buffers using HidD_SetNumInputBuffers() is working. Thank-you very much for this.
    Without this call however, we still see a limit of 64 bytes, not 32 reports as per the documentation link that you provided !
    Are you aware of any difference (other than the maximum number of buffers) under Windows 2000 ?
    Thnaks again for all your assistance.
  • A quick follow-up...
    It was my mistake regarding Windows XP; my colleague was actually using Windows 2000.
    A quick check with HidD_GetNumInputBuffers() shows that under Windows 2000, the default is 8 reports while under Windows XP, the default is 32.
    The microsoft documentation at msdn2.microsoft.com/.../ms790946.aspx is wrong (or at least inaccurate) as it appears to suggest that the default is 32 on both.
    Thanks Tsuneo for all your help.
  • "Our wMaxPacketSize is typically only 8 or 16, the same size as our maximum HID report, so we have no need to split reports into multiple frames."
    I don't recommend you to set wMaxPacketSize to other number than 64 for full-speed interrupt and bulk EPs. Surely, the USB spec allows any number (<= 64) for interrupt EPs, and 8, 16, 32, 64 for bulk ones. However, 64 is the de-fact standard; most of devices apply this number, and the host USB stack may not test fully for other numbers.
    "Our host app calls ReadFile() something like the following"
    Check the return value of ReadFile, first.
    OVERLAPPED ReadFile returns TRUE, when it immediately completes the request. This occurs when the input-report buffer already holds enough number of reports for the request.
    When it returns FALSE, confirm that GetLastError returns ERROR_IO_PENDING. Now you can safely apply WaitForSingleObject.
    "Are you aware of any difference (other than the maximum number of buffers) under Windows 2000 ?"
    I've once seen that the MS KB refers briefly to Win2k bug on reading out multiple reports using ReadFile. It was just a comment on an example file of the MS KB. But I cannot find it again...
    Tsuneo
  • See this MS KB article for the details of OVERLAPPED ReadFile handling.
    "Asynchronous Disk I/O Appears as Synchronous on Windows NT, Windows 2000, and Windows XP"
    support.microsoft.com/.../en-us
    When OVERLAPPED ReadFile completes synchronously and returns TRUE, the event object in the OVERLAPPED structure is not signaled. WaitForSingleObject results timeout in this case, though the readout actually succeeds. I think this is the cause of the data drop.
    Tsuneo
