C515C + PWM
Hi every body, and happy new year to all keil users ;)
I am using the C515C with keil v2.39,
I want to generate a PWM signal using one of the pins 1.0,1.1,1.2 or 1.3,
I read the manual, put I found it difficult, because I have to configure different things.
Like the following parameters:
T2CON |= 0x10; ET2=1; EXEN2=0; CRCL = 0x22; CRCH = 0xFF; EX3=0; CCL1 = 0xFF; CCH1 = 0x22; EX4=0; CCL2 = 0x00; CCH2 = 0x00; EX5=0; CCL3 = 0x000; CCH3 = 0x000; EX6=0; CCEN = 0xAA;
What I know, is that we have to use compare mode 0.
But how can I set T2 to be ready for all things, and how I change the duty cycle while from the program results...
Is there any ready function that has one input which is the duty cycle?
And thank you for your time.
  • ,,, no one answered me ,,,!!
    Please friends try with me...
  • Maybe it would help if you re-posted your source code so that it's actually legible?
    See: www.danlhenry.com/.../keil_code.png
    "I found it difficult, because I have to configure different things."
    Yes, that is the very nature of the exercise!
  • Don't Infineon provide any examples?
  • Thank you Mr. Andy...
    I have no problem in posting the code, if i have a code for the PWM...
    My program calculates digital values and then i need to convert them to analog, using RC circuit after the PWM signal...
    I don't need a very complicated specifications in the PWM signal, But in the programming I should pass through different things like disabling this and enabling that.. And then do this,
    I need one pin that gives me a PWM signal and the duty cycle say it is between 0.5 to 1 second...
    Thank you again for your time, and forgive me I am really a beginner in timers things..
    thanks alot...
  • The duty cycle of a PWM signal is the proportion of the time when it is in one state compared to the other state.
    So, you can't say that a duty cycle is in seconds. You either have to specify two times, or specify the duty cycle as a percentage, fraction or quota. In short, the duty cycle does not have a unit.
    A period on the other hand do have a unit, since it is a measurement of time.
    Doesn't the datasheets and the application notes for the chip contain the relevant information how to configure and use the PWM unit?
  • I thank every body that trying to help me....
    I think we miss understand each other...
    Let me put it this way...
    I have a calculation problem, and I need its result to appear as analog signal,
    By using a PWM, and changing its duty cycle according to the result..
    I need to set up my microcontroller to give me the output...
    The datasheet give information about that. And some examples are there,
    But some of them are not for the C515C and some of them are using the serial communication and so on...
    What is the mode, the TCON value, the ET2 , EXEN2 , CRCL values...
    i am realy lost...
    thank you again...
  • What is the mode, the TCON value, the ET2 , EXEN2 , CRCL values...
    i am realy lost...
    for sure you are. I never thought I would say this, but you are reading too much. T2 is an independent, unique timer and what you can find about T0 and T1 (e.g. TCON) has no effect whatsoever on T2.
    It seems your device has some unique SFRs but a very simple method could be
    void T2ISR(void) interrupt x using y
      TF2 = 0;
      TR2 = 0;
      if (onflag)
         TH2 = OfftimeH;
         TL2 = OfftimeL;
         onflag = 0;
      else
         TH2 = OntimeH;
         TL2 = OntimeL;
         onflag = 1;
      TR2 = 1:
    Then wherever you get the information re duty cycle you do this
       TR2 = 0;
       OfftimeH = xxx;
       OfftimeL = xxx;
       OntimeH = xxx;
       OntimeL = xxx;
       TR2 = 1;
  • You could go to the Infineon website and download DAvE. This tool can guide you in the configuration of T2 and CC1 (I would avoid CC0 if you want to have an automatic reload of T2 on an overflow of T2). DAvE is a GUI that generates your source files and in addition will create a plug in which Keil can directly import and create your project.
    So a simple example to generate a PWM on CC1 (P1.1) with T2 assuming that you are running at 10 MHz.
    You would configure T2 to work in timer mode and this could and you have only two choices for the prescaler fcpu/6 or fcpu/12. You mentioned in your post you wanted to use compare mode 0 and were looking for a duty cycle of .5 to 1 second. This would require some more work as the time base of the T2 does not support this when the cpu is running at 10 MHz.
    You maximum frequency for the period would be 12/10MHz * 65535 = 78.64msec.
    If you don't use the CC0 resources then you could use its registers CRCL and CRCH to automatically reload T2 if you wanted a shorter period. You would use mode 0 of T2 for this.
    You sated that you wanted to use compare mode 0. In mode 0, upon matching the timer with the compare register contents, the output signal changes from low to high. It goes back to a low level when the timer overflows. As long as compare mode 0 is enabled, the appropriate output pin is controlled by the timer circuit only, and not by the user. Writing to the port will have no effect. The port latch is directly controlled by the two signals timer overflow and compare. The input line from the internal bus and the write-to-latch line are disconnected when compare mode 0 is enabled. Once set up, the output goes on oscillating without any CPU intervention (could be referred to as a set and forget PWM).
    For duty cycle control this is generally referred as the amount of time the signal is on (high) during the period. To calculate the DC you could make something that brings you down to simple math (but you also need to "understand" the external hardware configuration, your filter). You could choose a period where the count is 20000 so you could then control the DC by multiplying by 200 for every percent of DC you want.
    So if you wanted a 50% DC then 200 * 50 = 10000.
    CRCL/CRCH = 65535 - 20000 = 45535
    CC1L/CC1H = 45535 + 10000 = 55535
    You could use the compare interrupt to change the value of the compare.
    Hope this helps.
    -Chris
    #include "REG515C.H"
    bit updateDC;
    unsigned char dcLo;
    unsigned char dcHi;
    unsigned int value;
    void SetDC(unsigned char dc) {
      value = (200 * (100 - dc)) + 45535;
      dcLo = (unsigned char) value;
      dcHi = (unsigned char) (value>> 8);
      IEX4 = 0;
      EX4 = 1;
    void T2_viIsrCh1(void) interrupt 11 {
      CCL1 = dcLo;
      CCH1 = dcHi;
      EX4 = 0;
    void T2_vInit(void) {
      TL2 = 0xDF;
      TH2 = 0xB1;
      T2CON |= 0x91;
      CRCL = 0xDF;
      CRCH = 0xB1;
      CCL1 = 0xEF;
      CCH1 = 0xD8;
      CCEN = 0x08;
    void main(void) {
      SYSCON = 0x20;
      T2_vInit();
      WDTREL = 0x80;
      WDT  = 1;
      SWDT = 1;
      IRCON = 0;
      EAL = 1;
      while(1) {
        WDT=1;
        SWDT=1;
        if (updateDC == 1) {
          updateDC = 0;
          SetDC(25);
  • Ok..
    Thank you Mr. Chris for helping me,, and thank you also for your explanations that helped me a lot,
    This is the first time I am using a PWM and timers staff, so please forgive me if I bored you in my basic questions.
    Ashraf,
  • After trying PWM program, I added it to my software but I found that it is not working with my program, I am using timer 0 for doing a delay which is used for the LCD. When the execution starts the PWM signal appears, the LCD works for a very short time. And then the execution starts again!!
    Is it possible making a priority solves the problem, and I tried to change the values of IP0 and IP1, but I did not get any change
    Is it possible that I am using the wrong bank register?
    Please some one look to my software and try with me…
    Ashraf,
    T0 Intialization is:
    void T01_vInit(void)
      TMOD = 0x31;
      TL0 = 0x00;
      TH0 = 0x00;
      TL1 = 0x00;
      TH1 = 0x00;
      ET0 = 1;
      TCON = 0x00;
    and the delay function is:
    unsigned int ctr;
    void T01_viIsrTmr0(void) interrupt T0INT
      T01_vClearTmr(TIMER_0);
      T01_vLoadTmr(TIMER_0,0xF82C);
      T01_vStartTmr(TIMER_0);
      ctr++;
      TF0 = 0;
    void delay(unsigned int delay_msec)
      ctr=0;
      while(ctr<delay_msec);
    In another way, this timer function T0, works fine without adding the PWM program
    What are the modifications should I change to make them works simultaneously?
  • please,, any help in my problem..
  •   T01_vClearTmr(TIMER_0);
    are you 'overmacronizing' or are these function calls? why make a macxro for what you do just once and AVOID LIKE THE PLAGUE function calls from ISRs.
    why do you even involve the main for PWM it should be totally handled in an ISR (except stating the width)
    why do you not try my suggestion - that was, indeed, help
  • Mr.Erik,
    I really appreciate your help, but the problem is that I did not understand what is x,y and how I change the duty cycle during the program...
    The given program from Mr.Chris is exactly what I need in a very simple way that I can understand as a beginner.. But it has a problem when I use T0 to have the delay,,,
    so, how can I modify one of the two programs to get my needs... (T0 ---> delay function and T2 ---> PWM) and no one interrupts the other...
    and thank you all..
  • I did not understand what is x,y and how I change the duty cycle during the program
       OfftimeH = xxx;
       OfftimeL = xxx;
       OntimeH = xxx;
       OntimeL = xxx;
    you set Offtime to 0x10000-the number of timer clocks you want the PWM output to be low you set Ontime to 0x10000-the number of timer clocks you want the PWM output to be high, you can change that any time and on the next timer interrupt the new time will be used.
    can't help you there, I do not know your derivative, what I have presented is derivative independent and will work on any '51 with a P2.
    Good luck,
  • Running T0 and T2 are independent and you didn't give an example that someone could reproduce to see an issue.
    From my point of view I don't understand how you are making the delay using T0. Is it that you want T0 to be a fixed timeout and you want it to be a multiple for your delay function?
    Where did you start T0?
    What about the watchdog?
    Here is a simple example that runs on the C515C WITHOUT issue.
    bit updateDC;
    unsigned char dcLo;
    unsigned char dcHi;
    unsigned char dc;
    unsigned int value;
    unsigned int ctr;
      IEX4 = 0;
      EX4 = 1;
      CCL1 = dcLo;
      CCH1 = dcHi;
      EX4 = 0;
    void T01_viIsrTmr0(void) interrupt 1 {
      TL0 = 0x73;
      TH0 = 0xF9;
      ctr++;
      TF0 = 0;
    void delay(unsigned int delay_msec) {
      ctr=0;         /* clear value */
      TL0 = 0x73;
      TH0 = 0xF9;
      TR0 = 1;       /* start T0  */
      while(ctr<delay_msec) {
        WDT=1;
        SWDT=1;
      TR0 = 0;      /* stop T0 */
      TL2 = 0xDF;
      TH2 = 0xB1;
      T2CON |= 0x91;
      CRCL = 0xDF;
      CRCH = 0xB1;
      CCL1 = 0xEF;
      CCH1 = 0xD8;
      CCEN = 0x08;
    void T01_vInit(void) {
      TMOD = 0x01;
      ET0 = 1;        /* Timer 0 interrupt enabled */
      TCON = 0x00;
    void main(void) {
      SYSCON = 0x20;
      T2_vInit();
      T01_vInit();
      WDTREL = 0x80;
      WDT  = 1;
      SWDT = 1;
      dc = 75;       /* set DC to 75% */
      IRCON = 0;
      EAL = 1;
      while(1) {
        delay(100);         /* delay ~100 msec */
        P1 ^= 0x04;         /* toggle P1.2    */
          updateDC = 0;
          SetDC(dc);
