hi friends,
this is part of the code used to read the binary data from a motorola Oncore gps timing RX (they do/did a version that can output 10Khz as well).
its got 4 errors so plz tell me what is bad
GetRx call readst ; read receiver data string iorlw 0 ; test W, 0 = checksum good btfss status,z ; if read error do not update lcd return ; Call again for second string call readst ; read receiver data string iorlw 0 ; test W, 0 = checksum good btfss status,z return ; if read error do not update lcd MOVLW 0x01 ; Clear LCD CALL cout CALL chkbsy movf day,w ;Send date call p_bin movlw '-' call dout movf month,w call p_bin movlw '-' call dout movf year_hb,w movwf hbyte movf year_lb,w movwf lbyte call bin2bcd call p_4 ; send 4 lsd from "R" reg to LCD movlw ' ' ; send space call dout movf hour,w ; send time return
If you feed this code into an 8051 assembler, you'll probably get more than just 4 errors, because it's not 8051 assembly at all !
Also, knowing what those mysterious 4 errors are would be very helpful for anyone trying to help you with your problem. And if you post errors, copy&paste them - do not re-type them.
no
i been told the code has 4 eroors but i dont know what it is
do you see?
Well, if this is code intended for an 8051-compatible processor, then the solution is very simple - it is assembly written for a totally different type of processor.
I would guess that it is actually code for a PIC processor. And since none of the products made by Keil are intended to be used with PIC processors, you would be looking for answers in the wrong place.
"I been told the code has 4 eroors"
And, presumably, your assignment is to identify those erros?
Asking others to do your homework for you is cheating
no the code you saw was not rite!
this is the code
MOV R4,A MOV R2,#6 CharLoop: MOV A,R0 MOVX A,@A+DPTR MOV P7,R0 INC RA INC R2 CJNE R1,#9,CharLoop RETF </pre<
Asking others to do your homework for you is still cheating!
you post the wrong code i.e. you do not even recognize that the code is not for a '51 and then you ask us to help you cheat.
If you can not even identify '51 code as opposed to PIG? code it would be the ultimate disservice to you and whereever you eventually apply for a job to 'help' you. You would probably not even manage to earn a days wages before you were found out and dismissed.
Either you are dumb, lazy or whatever or you better ask the institution you attend for a refund.
i have no good ansewr for my problem i have got one bug but have not found anotehr
you pl help with other and give one each
Why? Don't you think school work is foor school students?
You need to do two things:
1. Use the assembler to show you the syntax erros;
2. Use the simulator to step through the code, and observe what happens.
In fact, you could do both of them just with pencil & paper and referring to the Instruction Set manual - Chapter 2 of the so-called "bible" for the 8051:
Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf
Chapter 2 - 80C51 Family Programmer's Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf
Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
The errors are blatantly obvious. A review of 8051 registers and instructions would be a good place to start.
all you need help with can be found in "the bible" and the specific questions are 'answered' in cahapter 2
Chapter 2 - 80C51 Family Programmer’s Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf
you will, of course need it all, so here are the links to all "the bible" Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf
"you pl help with other and give one each"
And do you think this approach will be allowed when you have to sit your exams...?
my code complies now :=)
and i now put in coments to understand
but do you think it dorks?
MOV R4,A // load register wit a MOV R2,#6 // number of bits CharLoop: MOV A,R0 // load a agin MOVC A,@A+DPTR // ?????????? MOV P0,R0 // get next key INC R4 // add 1 INC R2 // again CJNE R1,#9,CharLoop // branch if 9 RET <pre/
You've never given even the remotest hint of what it is supposed to do, so how can anyone possibly tell whether it does that or not!
Most of your comments add nothing that is not directly obvious by simply looking-up the instruction in the manual. The whole point of commenting code is to explain what it is trying to achieve - not simply reiterating what is obvious from the instructions themselves!
