TCPnet: PPP issue trying to connect to windows
I am using the RL-ARM TCPnet in an attempt to set up a PPP connection to Windows XP over a null modem cable.
The connection seems to work for a while--I am using the debugger library RTLCD.lib and am able to verify that PPP packets are being exchanged between Windows and RL-ARM. Unfortunately, before authentication has finished, the link seems to stop working...
ppp_is_up( ) never returns TRUE. Here are the last several debug messages received.
PPP: *** Processing PPP-LCP frame ***
PPP:  LCP Config Request received.
PPP: Sending PPP frame...
PPP:  Frame len: 12
PPP: *** Processing PPP frame ***
PPP:  Frame len: 29 bytes
PPP:  Protocol:  C021
PPP:  Frame len: 12
PPP:  Protocol:  C021
PPP:  Frame len: 12
The beginning messages may actually prove more useful as there is a Rejecting Unsupported Config Options message:
PPP: Dialing number: *
PPP: Username: 'Test', Password: 'Test'
PPP: Sending LCP Configuration request.
PPP:  Frame len: 26
PPP:  Frame len: 63 bytes
PPP:  Protocol:  C021
PPP:  Rejecting Unsupported Config Options.
PPP:  Frame len: 44
PPP:  Frame len: 24 bytes
PPP:  Protocol:  C021
PPP:  LCP Config Acknowledge received.
PPP:  Async Char MAP: 00,00,00,00
PPP:  Enabled PF Compression
PPP:  Enabled ACF Compression
PPP:  Magic Number: 00295AF7
I am trying to establish this connection with the microcontroller as the client and Windows XP as the host. On Winodws XP: I set up the modem: Communications cable between two computer and created an Incoming Connection for which I enabled TCP/IP and set Allow callers to access my local area network, Assign TCP/IP addresses automatically using DHCP and checked Allow calling computer to specifiy its own IP address
My code uses Keil's null_modem.c driver. In Net_Config.c, I enabled Obtain Client IP address automatically, so therefore the IP address and Subnet Mask fields do not matter, correct?
I am using the latest release of RL-ARM (3.13a), and the latest release of MDK-ARM 3.15b. This code is for the ARM7 LPC2378 microcontroller, on Keil's MCB2300 board.
I would appreciate any advice! I am very new to PPP. Thanks!
-Eric
