Linker warning L13 with function pointers
I want to call a number of functions with function pointers. I have studied a number of posts and App. notes, including APNT 129 and I am still getting a linker error. On page 7 of APNT 129 is says:-
The following is a function pointer table definition that C51 and BL51 can handle automatically:
code long (code *fp_tab []) (void) =
{ func1, func2, func3 };
Note that the only difference is storing the table in CODE space.
and later:-
As long as the function pointer table is located in a separate source file, C51 and BL51 make all
the correct links in the call tree for you.
I assume the .h file is OK for "a separate source file"
Here is my code:-
in the myprog.h file:-
extern uchar set_day(uchar xpos, uchar ypos, uchar action);
extern uchar set_hours(uchar xpos, uchar ypos, uchar action);
extern uchar set_mins(uchar xpos, uchar ypos, uchar action);
// Function pointer table
code uchar(code *set_table[])(uchar, uchar, uchar) = {set_day, set_hours, set_mins};
in the myprog.c file:-
#include "myprog.h"
/* Declarations*/
main(){
// function called with:-
(*set_table[0])(an_xval, a_yval, an_action);
// Functions:- (after main() in myprog.c)
uchar set_day(uchar xpos, uchar ypos, uchar action){
set_hours(uchar xpos, uchar ypos, uchar action){
set_mins(uchar xpos, uchar ypos, uchar action){
When I link this, I get three L13 warnings.
The M51 file reports:-
PROGRAM RECURSIONS REMOVED FROM CALL TREE
+--> ?CO?RGE_MAIN_04
<--+ ?PR?_SET_DAY?RGE_MAIN_04
<--+ ?PR?_SET_HOURS?RGE_MAIN_04
<--+ ?PR?_SET_MINS?RGE_MAIN_04
*** WARNING L13: RECURSIVE CALL TO SEGMENT
    SEGMENT: ?CO?RGE_MAIN_04
    CALLER:  ?PR?_SET_DAY?RGE_MAIN_04
    CALLER:  ?PR?_SET_HOURS?RGE_MAIN_04
    CALLER:  ?PR?_SET_MINS?RGE_MAIN_04
I would rather not have these warnings but is it safe to ignore them, bearing in mind the code seems to work when I download it. (I have only called the first pointer so far.)
