the ISR runs only for the first time. I'm not sure if the settings for the interrupt are correct. Can anyone explain me the difference between ASC0_RIC_IR and ASC0_RIC
thanks for help
Rainer
void rs232_open() {
ASC0_CON = 0x8011; // set serial mode // Baudrate Generator disabled,Baudrate timer prescaled divide by 2 // even parity, ignore Parity, Receiver enabled REN = 1, One Stop Bit // 8 Bit data asyncron Mode
ASC0_BG = 0x81; // set baudrate fix Input Clock Dividers // 19200Baud 0x40/0x41 // 9600Baud 0x81/0x82
ASC0_TIC = 0x80; // set transmit interrupt flag ASC0_RIC = 0x45; // delete receive interrupt flag
void int_232_serv() interrupt intreg = 43 {
register BYTE c; ASC0_RIC_IE=0; // Receive interrupt disabled
c = ASC0_RBUF;
Receive = TRUE;
ASC0_RIC_IR = 0; ASC0_RIC_IE = 1; }
has anyone a example for a loop back serial ISR routine for the xc161 Controller like the example for the 8051
void rs232_open( ) {
PCON = 0x80; SCON = 0x50; RCAP2H = 0xFF ;
RCAP2L = 0xFA ; // T2CON = 0x34 ; // baud ES = 1; }
void int_232_serv() interrupt 4 { register BYTE c, nextp;
if( RI ) { // receiver interrupt c = S0BUF;
RI = 0 ; } else if( TI ) { // transmitter interrupt
S0BUF = c; TI = 0 ; } }
Thanks for help
Here is an example for the XC16x:
#include <xc161.h> #include <intrins.h> void ASC0_Init(void) { /* Configuration ASC0 Baudrate Generator to 9600 Baud (20MHz clock) */ ASC0_BG = 0x0040u; /* 8-bit data asychronous operation with one stop bit receiver is enabled */ ASC0_CON = 0x0011u; /* P3.10 is used for ASC Transmit Data Output */ /* P3.11 is used for ASC0 Receive data Input */ ALTSEL0P3 |= 0x0400u; _bfld_ (P3, 0x0C00u,0x0400u); /* set output for Tx pin */ _bfld_ (DP3,0x0C00u,0x0400u); /* write diections for tx and Rx */ /* Tx interrupt, (ILVL) = 13,(GLVL) = 1,(GPX) = 0 */ ASC0_TIC = 0x0075u; /* Rx interrupt, (ILVL) = 13,(GLVL) = 0,(GPX) = 0 */ ASC0_RIC = 0x0074u; ASC0_CON |= 0x8000u; /* enable baud rate generator */ } void ASC0_TxISr(void) interrupt 0x2A { /* not needed in this example */ } void ASC0_RxIsr(void) interrupt 0x2B { ASC0_TBUF = ASC0_RBUF; /* echo byte back */ } /* entry point*/ void main(void) { ASC0_Init(); /* initialize the serial port */ PSW_IEN = 1; /* globally enable interrupts */ for(;;); /* loop forever */ }
