LPC2378 - External Memory Controler strange behaviour
I'm using LPC2378 with 4 Mbits FRAM, and so I have to manage 8 banks
of 64Ko (only CS0 is ised as chip select).
I wrote a test program that filled each bank with a continuous
upcounting 32 bits value. But last bytes of each bank are altered: it
seems the write buffer is not empty and the write is not finished when
I change the bank select.
So , there's a EMC Status register I want to chech before changing banks.
From the lpc2378 user manual :
EMC Status Register (EMCStatus - 0xFFE0 8004)
bit 0 : B Busy.
This bit is used to ensure that the memory controller enters the
low-power or disabled mode cleanly by determining if the memory
controller is busy or not:
0 EMC is idle (warm reset value).
1 EMC is busy performing memory transactions, commands, auto-refresh
cycles, or is in self-refresh mode (POR reset value).
bit 1 : S Write buffer status.
This bit enables the EMC to enter low-power mode or disabled
mode cleanly:
0 Write buffers empty (POR reset value)
1 Write buffers contain data.
bit 2: SA Self-refresh acknowledge. This bit indicates the operating
mode of the EMC: 1
0 Normal mode
1 Self-refresh mode (POR reset value).
But when you read this register it's always returning 0x05 (the reset
value). According th this value,the ECM is always busy and in self
refresh !!!
I understand self refresh means nothing for static RAM, but nowhere in
the manual there's DRAM related topics ...
So why there's a self refresh activated and how to disable it?
And finally how can I get the status register functionnal ?
Thanks in advance .
