hi, i'm using a- 80c31 microcontroller to send the status of port bits: p3.3,p3.4,p3.5 using serial comm. my program works fine only in simulation and i cant get an idea where is the problem. i checked the TX pin(11) with a scope and it seems that no data are being sent.
please help...
#include <Reg51.h> sbit Input1 = 0xB3; /* P3.3 */ sbit Input2 = 0xB4; /* P3.4 */ sbit Input3 = 0xB5; /* P3.5 */ unsigned int Tmr1 = 0; unsigned int Tmr2 = 0; unsigned int Tmr3 = 0; void SendStatus() { if (Input1 == 0){ P2 = P2 | 0x03; Tmr1 = 0; } if (Input2 == 0){ P2 = P2 | 0x18; Tmr2 = 0; } if (Input3 == 0){ P2 = P2 | 0xC0; Tmr3 = 0; } TI = 0; SBUF = P2; while (TI == 0); /* Wait For Transmit */ if (TF0 == 1) { Tmr1 = Tmr1 + 1; Tmr2 = Tmr2 + 1; Tmr3 = Tmr3 + 1; if ((Tmr1>912)&&(Tmr2>912)&&(Tmr3>912)) { Tmr1 = 0; Tmr2 = 0; Tmr3 = 0; TR0 = 0; TF0 = 0; P2 = 0x00; } else if (Tmr1 == 912) {/* 60 Sec Alarm Hold*/ P2 = P2 & 0xFC; } else if (Tmr2 == 912) {/* 60 Sec Alarm Hold*/ P2 = P2 & 0xE7; } else if (Tmr3 == 912) {/* 60 Sec Alarm Hold*/ P2 = P2 & 0x3F; } else { TH0 = 0xFF; TL0 = 0xFF; TF0 = 0; } } } void main() { SCON = 0x40; /* 8-bit UART, BaudRate set by Timer-1 */ TMOD = 0x21; /* Timer1 mode 2, Timer-0 mode 1 */ TCON = 0x40; /* Start baud clock */ TR0 = 0; /* Turn Timer-0 off */ TH0 = 0xFF; TL0 = 0xFF; TF0 = 0; /* Clear rollover flag */ TR0 = 0; /* Turn timer-0 on */ TH1 = 0xCC; /* 600 baud 12MHz */ IE = 0x00; /* Disable serial int */ IP = 0x80; /* Interrupt priority stopped */ P2 = 0x00; P3 = 0x00; Input1 = 1; Input2 = 1; Input3 = 1; while(1) { while ((Input1 == 1)&&(Input2 == 1)&&(Input3 == 1)) { TI = 0; SBUF = 0x00; while (TI == 0);/* Wait For Transmit */ } TH0 = 0xFF; TL0 = 0xFF; TR0 = 1; /* Turn timer-0 on */ while (TR0 == 1) SendStatus(); } }
i'm using a- 80c31 microcontroller to send the status of port bits: p3.3,p3.4,p3.5 using serial comm. my program works fine only in simulation and i cant get an idea where is the problem. i checked the TX pin(11) with a scope and it seems that no data are being sent. I do not know what you "send the status of port bits" to, but guess some RS232 device like a PC. THEN i checked the TX pin seems to indicate that you do not have a MAX232(equivalent) in the chain, in which case P3.0 and P3.1 most likely are blown.
80c31 why on earth? these days there are derivatives galore with internal flash at all kinds of prices with all kinds of features. Are you a nostalgia buff?
hi, Erik
first of all, i'm working with a pcb layout that implemented in other configuration,(for 10 years now) that is why i keep working with 80c31.
i'm sending the status of the port bit because they are connected to 3 dry contacts of a relay which i monitor: open(1) or close(0).
the TX pin is connected to a ADM233L which converts it to RS232 for the PC COM port.
thanks
Check my 'whittling', try this and then answqer
does this make The Txd pun toggle?
#include <Reg51.h> void SendStatus() { TI = 0; SBUF = P2; while (TI == 0); /* Wait For Transmit */ } void main() { SCON = 0x40; /* 8-bit UART, BaudRate set by Timer-1 */ TMOD = 0x21; /* Timer1 mode 2, Timer-0 mode 1 */ TCON = 0x40; /* Start baud clock */ TH1 = 0xCC; /* 600 baud 12MHz */ while(1) { SendStatus(); }
Are you using the aboninable tab character Erik? Your indents seem a bit short ;)
Hmm. Strange spelling for abominable...
naah, cut and paste from the OP. OK maybe I should have cleaned his stuff up a bit better, but it was not "here is the code" but "do something like this"
Yep, Erik your short code is work.
but what's wrong with mine...
find it out
gradually add the rest, when it stops working you'll know.
i have encounter in a strange situation that must be solved and understand, with the help of experts or people smarter than me of course.
All i want to do is to monitor 3 bits of P3: P3.3,P3.4,P3.5. the default state of the pins is '1'.(by pull up resistor)
i monitor (with scope) the pin Txd (P3.1) while i'm simulating the bits aforementioned. when i set the P3.3 to 0 the output is OK=> SBUF=0x01. but when i set the P3.4 or P3.5 then the result of SBUF is inconstant: P3.4=0 => SBUF=0x02(OK) and changing to SBUF=0x80(BAD) alternately. and when i set P3.5=0 => SBUF=0x04(OK) and changing to SBUF=0x40(BAD),alternately.
it seems like the value of sbuf is shifting according to the time that i set each bit to '0'.
#include <Reg51.h> sbit Input1 = 0xB3;// P3.3 (INT1) bit set, Input 1 sbit Input2 = 0xB4;// P3.4 (T0) bit set, Input 2 sbit Input3 = 0xB5;// P3.5 (T1) bit set, Input 3 char TxOK = 0; // Software transmission flag void serial_IT(void) interrupt 4 { if (TI == 1) { // if reception accur TI = 0; TxOK = 0; // Clear software transmission flag } } void main(){ SCON = 0x40; // 8-bit UART, BaudRate set by Timer-1 TMOD = 0x20; // Timer1 mode 2, Timer-0 mode 1 TR0 = 0; // turn timer0 off TCON = 0x40; // Start baud clock TH1 = 0xE6; // 1200 baud 11.0592MHz TL1 = 0x00; ES = 1; // Enable Serial Int EA = 1; // Enable Globale Int TI = 1; // send buffer first while(1){ ACC = 0x00; if (Input1 == 0) { ACC = 0x01; } if (Input2 == 0) { ACC =ACC | 0x02; } if (Input3 == 0) { ACC =ACC | 0x04; } TxOK = 1; SBUF = ACC; while(TxOK); } }
Is "Nir Bohadana" the same person as "Nir boh" - who started this thread?
Your code is almost certainly doomed to failure:
while(1){ ACC = 0x00; if (Input1 == 0) { ACC = 0x01; } if (Input2 == 0) { ACC =ACC | 0x02; } if (Input3 == 0) { ACC =ACC | 0x04; } TxOK = 1; SBUF = ACC ; while(TxOK); } }
In a high-level language such as 'C', you simmply cannot rely upon any processor register such as ACC retaining its value across statements.
So your first step must be to rewrite this properly in 'C' using a local variable to store your intermediate values...
yes i'm the same person.
OK, i'll try this in a couple of minutes.
thanks.
can you write the line for me that declare a local variable to store the bits before sending them to the SBUF.
i'm confused with unsign char ,char ....
"i'm confused with unsign char ,char ...."
What, specifically, is the confusion?
Sounds like you need a 'C' textbook?
http://www.keil.com/books/
that is waaaay too 'politically correct'
i changed my program, and still i found some odd things..
the result are as this
send >expected output> alternate output 1...........0x01..............0x40 2...........0x02..............0x20 3...........0x03..............0xA0 4...........0x04..............0x10 5...........0x05..............0x50 6...........0x06..............0x90 7...........0x07..............0xB0
the alternate output accures when i trigger the input bit again.
#include <Reg51.h> sbit Input1 = 0xB3; /* P3.3 (INT1) bit set, Input 1 */ sbit Input2 = 0xB4; /* P3.4 (T0) bit set, Input 2 */ sbit Input3 = 0xB5; /* P3.5 (T1) bit set, Input 3 */ unsigned char TxOK = 0; unsigned char xt = 0; void serial_IT(void) interrupt 4 { if (TI == 1) { TI = 0; TxOK = 0; } } /* ~~~~~~~~~~ */ /* Main Sub */ /* ~~~~~~~~~~ */ void main(){ SCON = 0x40; TMOD = 0x20; TR0 = 0; TCON = 0x40; TH1 = 0xCC; TL1 = 0x00; ES = 1; EA = 1; TxOK = 1; TI = 1; while(TxOK); while(1){ if (Input1 == 0) { xt = 1; if (Input2 == 0) { xt = 3; if (Input3 == 0) { xt = 6; } } else if (Input3 == 0) { xt = 4; } } else if (Input2 == 0) { xt = 2; if (Input3 == 0) { xt = 5; } } else if (Input3 == 0) { xt = 7; } else xt = 0; TxOK = 1; SBUF = xt; while(TxOK); } }
