MEMORY ALLOCATION RTX
Dear All,
I have need mor informations on RTX memory allocation.
I have created a task with this memory allocation
char str[400];
memset( &str, 0x0, size(str) );
I have this configuration on RTX_Config.c
OS_STKSIZE 50 //200Byte for task
With this configutarion I have a block application but I have block application also with "char str[200];"
Why? How do I use the function "sys_error (ERROR_CODE code)" that I have found in other demo project?
Is it possible to management memory fault
A last question... What do the OS_PRIVCNT
Thanks a lot
Luc
  • I don't understand what you mean with "a block application".
    Your variable char str[400];
    seems to be a global variable. No memory allocation involved, so no memory allocation that can fail.
    From comments in RTX_Config.c:
    //   <o>Number of tasks with user-provided stack <0-250>
    //    Define the number of tasks that will use a bigger stack.
    //    The memory space for the stack is provided by the user.
    //    Default: 0
