Application not running after flashing when OPTIMIZATION option selected in KEIL uVision3 V3.53
Hi
We are using KEIL uVision3 V3.53 for our application development.
The nxp controller we use is P89LPC9408, which has a CODE size of only 8K.
Since our application got over 8K -
Program Size: Data = 243.5 xdata=194 code=8889
So I chose the PEEPHOLE OPTIMIZATION in code optimization option in uVision3.
then the Program Size: Data = 193.5 xdata=207 code=7884
After optimization the application can be run using EPM900 emulator. But it is not running after flashing to the actual hardware for that product .
Then I tried flashing after removing some modules to reduce code size below 8K and I chose optimization level 0. This time the application can run in flashed units. This time the program size is Program Size: data=182.5 xdata=209 code=7617 without optimization.
Please let us know, what could be reasons for the Optimized Code not running in flashed units.>
