Error: Flash Download Failed
Hallo,
I've received the error56, that I cannot open my programmed file.
I'm using the MCB2300 with LPC2368.
I don't have any Errors or Warnings inside my written Programm and I've done already the following things in the Options:
- veryfied under Utilities that I'm using the LPC2000 IAP2 512kB Flash
- veryfied under Debug that I'm using the ULINK ARM Debugger with the 200kHz JTAG Clock
- veryfied that all other Points in the Options are the same adjustments like every single time before.
I've already erased the Processor with Flash Magic.
My Questions:
Is there anything that I'm not noticed already ??
Is it perhaps possible that there's anything in my programm that causes the error ??
Has anyone an idea ??? ( because right now, I don't have any more )
thx
  • "...that I cannot open my programmed file..."
    Do you have any file to program, i.e. have you made sure that the linking step actually produces an output file that may be programmed?
    Does the programming fail instantly, or what happens before it fails?
  • In the Options for my Target I have veryfied that I'm creating an executable file.
    Actually I could create an *.afx & *.hex file in my Objects Folder and the Files are surelly there.
    But if i want to program it, I'm receiving the Error, that the Flash Download failed. He couldn't open the File and shows me the path of the file.
    But the path ist without an afx ending. If I'm succeeded to program a file, he will show me the path with the afx ending.
  • I've found it !
    It's not possible to flash the ULINK with a file that's named like I've done.
    I've named it USB_2.0 . That wasn't a good idea. Now I've renamed it to USB2 and fortunately it works.
    I didn't have a glue that this type of naming isn't possible.
    thx ...
