Hi all,
I'm using CodeWright 6.6. My project has many files with following extension:
- *.cpp: CodeWright identifies them as C++ files(It is ok.) - *.h: CodeWright identifies them as C++ header files(It is ok.) - *.cc: CodeWright identifies them as text files(It isn't ok.). CodeWright should read them as C++ files. Can you help me? What I should modify? How???
Thanks in advance Regards Marco
You do realise that CodeWright is not a Keil product, don't you? http://www.keil.com/forum/
Have you looked in your CodeWirght Manual, and/or checked the online help?
"CodeWright should read them as C++ files."
Why should it? As with any versatile, configurable tool, it's up to you to configure it correctly!
Hint: Look under Customize / Language...
