Hello! Can you help me with start up code to initialize CAPCOM6 unit of XC167 to generate PWM? I use MCB-XC167 board and XC16X.h register declaration file. My project doesn't work. My initialization is:
DP2 = 0xff00; P1L = 0x0000; DP1L_P0 = 1; DP1L_P1 = 1; DP1L_P2 = 1; DP1L_P3 = 1; DP1L_P4 = 1; DP1L_P5 = 1; ALTSEL0P1L = 0x003F; CCU6_T12PR = 200; CCU6_CC60R = 100; CCU6_CC61R = 50; CCU6_CC62R = 25; CCU6_CC60SR = 100; CCU6_CC61SR = 50; CCU6_CC62SR = 25; CCU6_T12MSEL = 0x0333; CCU6_T12DTC = 0x080A; CCU6_TCTR4 = 0x0002;
Maybe I forgot something.
take a look to http://www.infineon.com and search for application note AP1609710.
This application note shows PWM with the CAPCOM6. You can even find an uVision project in the EXE file for this appnote.
Link is: www.infineon.com/.../channel.html
Thanks a lot! It's very helpful for me. Can You suggest the best way to switch on/off PWM output? My task is to provide time diagram where PWM take turns with blank space. I try to start/stop T12 timer with TCTR4 bit T12RS but it has no influence on output.
