Logical Operator AND in uVision
I need to know what is wrong with uVision.
I had not seen this before.
I wrote this piece of code in uVisio, the program is not working well. When I simulated it, I realized the compiler is not doing the right process:
void Write_LCD(unsigned int A ){
unsigned int E;
E=0xf0&A; //here is the problem***
LCD_Data=e;
in ***, E=0xf0&A, the compiler does not execute the ligical operation AND, it passes the value of A to E and when I put parenthesis, this is E=(0xf0&A); it puts 0x00 to the variable E.
I wonder what is wrong with this instruction?
Thanks for your help.
