Dear sir presently we are doing an automotive project using LPC2368 controller. We are developing a receiver system which receives CAN messages from the CAN Network. We wants to implement the error handling in our project. We have to handle two errors in our system 1> Data Over-run 2> Error passive
We have written the codes for these errors but we are unable to get those errors in our system and we dont know exact procedure to simulate our code. Can you please provide some test codes so that we can generate these errors and handle them in an effective way.
And also we want some information regarding resetting of CAN controller Weather we have to reconfigure the CAN controller ( CAN initialization & Acceptance filter ) after bus off event or CPU initiated bus off event. Or previous configurations will be Reloaded (ie previously set baud-rate , Acceptance filter etc )
Thanks & Regards Giridhar
Besides simulating incoming Messages and Remote Frames via Virtual Register CANxIN you can also simulate CAN errors.
Following is the description of the Virtual Registers for CAN in LPC devices:
CANxIN and CANxOUT Values (x = 0, 1, .. 6): 1 - Message with 11-bit ID 2 - Message with 29-bit ID 3 - Remote Frame with 11-bit ID 4 - Remote Frame with 29-bit ID 5 - Bus Activity Start Arbitration Loss (captured in CANICR): Bit 5: 1 Bits 0..4: ALCBIT Bus Error (captured in CANICR): Bit 8: 1 Bits 0..4: ERRBIT Bit 5: ERRDIR Bits 6..7: ERRC
Errors are captured in the CANxICR register. So to simulate a CAN error you just need to write the appropriate command into the CANxIN (from the command window).
Examples:
CAN1IN = 0x2C; // Arbitration Lost (in IDE bit): ALCBIT=12 CAN1IN = 0x18A; // Stuff Error in Data Field while transmitting: ERRBIT=10, ERRDIR=0,ERRC=2
Can you please give some more information regarding those virtual registers . Or please send me the link which having information about those Virtual registers for CAN controller in LPC2000 series
thanks & Regards Girish
