I've installed a system timer (AT91RM9200 controller) - which runs without problems... I use this timer for several things.
Now I have critical code areas (only two lines of code) where no interrupt (of the st timer) is allowed to occur.
So (of course) I could disable the interrupts and after the critical code area I could enable the interrupts - but the problem is, that the interupt occurs only every one minute - so if I disable interrupts when the interrupt would occured in approximately 2 secs - and I need 4 sec until I could enable the interrupts again -> then I have to waite nearly one minute again that the next interupt occured... -> that's too long
Is there a possibility to know after the critical code area, if there was a interrupt (st timer)? so that the ISR is called (immediately) after the critical code area?
best regards Johannes
If you by "disable interrupts" means the global interrupt-enable flag, then you will not loose the timer interrupt (unless you disable the interrupt long enough that a second timer event gets blocked.
It is only if you disable the interrupt generation for the timer that you will loose the timer interrupt - since the interrupt flag will not be in the pending state until you enable interrupts again.
What do you do that requires a two second long critical section. Most of the time, critical sections are ns, us or possibly ms long. Anything that takes seconds are normally processed by a separate thread or by a state machine concurrently with other processing.
thanks for the fast reply...
the time should only describe my problem a little bit better - the critical section includes only one if() question and set a bit to default - thats it....
I would use the mask register of the st timer (period interval timer) - so that the Watchdog which is using the same timer would work during the critical section too....
What do you mean by interrupt generation for the timer? The timer has only a status register - if you read the PITs timer status - so you could see if a timer overflow occured since the last read.
