Dear All,
I have a MCB2300 with 2378... if you try download to flash memory I have this error:
No Algorithm found for: 00000000H - 00000953H Erase skipped! Load "C:\\Keil\\ARM\\Boards\\Keil\\MCB2300\\TEST\\TEST.AXF" Cannot enter Debug Mode Erase Failed!
First I have also these MessageBox :
1) Cannot Load Flash Programming Algorithm 2) Error: Flash Download Failed - ARM7TDMI
Thansk in advance
BR
Michele
You did not say in your post but I'm assuming you are using the uLink to program your device. If this is correct, go to Target Options->Utilites Tab. Check your settings. Select the 'Add' button and select LPC2000 IAP2 512kB Flash. I'm sure there are additional instructions in the User's Guide. Bradford
Hi; Along with the above suggestion Pleaseenable the .ELF in the output files and download the program using ULINK. It should do.
