Hi
Why does this declaration not work: char xdata *pointer _at_ postion;
but this one works: char xdata array[1] _at_ postion;
Should be theoretically the same, or not?
Thanks Egon
I'm sure someone here could give you specific references to manuals, but you should consider how the compiler treats each.
For simplicity, ignore the '_at' portion.
char xdata *pointer is allocating space for a pointer, the location of the pointer is at a specific location, but the value of which is variable (i.e., non constant).
char xdata array[1] is allocating space for a single byte of memory at a specific location (i.e., the location is constant).
So, clearly, they are not the same.
"Should be theoretically the same, or not?"
even leaving aside the Keil-specific 'xdata' extension, they are not the same at all!
one is an array; the other is just a pointer.
Regarding the Keil-specific 'xdata' extension - remember that there are two memory spaces to consider for a pointer:
1. The memory space where the pointer itself is located; 2. The memory space to which the pointer points.
www.keil.com/.../c51_le_memspecificptrs.htm
remember that there are two memory spaces to consider for a pointer here is my definitions, they should make it clear
// pointer in data in #define U8DI unsigned char idata * data // data idata #define U8DX unsigned char xdata * data // data xdata #define U8IX unsigned char xdata * idata // idata xdata #define U8XX unsigned char xdata * xdata // xdata xdata #define U8IC unsigned char code * idata // idata code #define U8DC unsigned char code * data // data code #define U8XC unsigned char code * xdata // xdata code #define U8CC unsigned char code * code // code code
note; no pointer point to DATA simply because that does not mak sense, there is no overhead from IDATA compared to DATA.
I really think that the OP needs to appreciate the basic difference before getting involved in the question of memory spaces and any other Keil specifics.
That is to say, he/she must appreciate that there is a difference between a pointer and an array.
My problem is I have to place the pointer at a specific location, hence the _at_ keyword. The pointed address is not the question here!
Then try:
xdata char *pointer _at_ location;
Just tried it here, works as I would expect.
"My problem is I have to place the pointer at a specific location"
What is it, exactly, that compels you to do that?
If this is not a real requirement, then why make life difficult for yourself?!
Your right, too much thinking today, therefore the confusion!!
Thanks for the link, the conversion of the generic pointer to a memory specific pointer solves the compiler error!
Thanks for the quick help
