HI Friends,
I am using AT91SAM7SE512 controller, i have configured the input in port B.while compiling the program i am getting this warning.
main.c(8): warning: #61-D: integer operation result is out of range main.c(8): warning: #68-D: integer conversion resulted in a change of sign.
If anybody knows about this bug Please help me to rectify.
The code is
#define test (1<<31) //PB31
int main() { // Enable the clock of the PIOB for led and PIO for Switch
AT91F_PMC_EnablePeriphClock ( AT91C_BASE_PMC, 1 << AT91C_ID_PIOB) ; AT91F_PIO_CfgInput (AT91C_BASE_PIOB , test );
} with regards, Nanju...
Declare test as unsigned long:
#define test (1UL<<31)
Hi friend,
Thanks for your suggestion.
Now there is no warning.
May i know the reason for this declaration. #define test ((unsigned long)1<<31) //PB31
because i declared other pins like this "#define test (1<<20) //PB31".For that no warnings,only the warning is giving this PB31 pin.
Please advise.
A 32-bit integer has exactly what out sounds like - 32 bits. They are numbered from 0 to 31, and for an unsigned integer represents the values 2^0 (=1) to 2^31 (=2147483648).
For a signed integer, a system called two's complement is used. Half the capacity is used to store negative values, limiting the largest positive value to every bit but the last one, i.e. 2^0 + 2^1 + 2^2 + ... + 2^30 (=2147483647). A signed integer will the most significant bit set represents a negative value.
Your operation (1<<31) would convert the positive number 1 into a negative value by moving the bit all the way into the last position, and the compiler complained. Specifically saying that the digit 1 was unsigned, by the suffix u (1u) tells the compiler that the integer should not be treated as a signed integer and that the most significant bit is available to be used without generating a warning.
For more information about the two's complement format, see this link: en.wikipedia.org/.../Two's_complement
Thank you very much dear friend.
