Hello, I'm working on XC164CM. I'd like to store code in RAM, not in flash memory.
The code is simple :
#pragma RENAMECLASS (FCODE=RAMPROG) void CallProgRam(void) { int i; for(i=0; i<666; i++); }
where the classes' range are: FCODE (0xC02200-0xC0FFFF), RAMPROG (0x00F600-0x00FDFF),
when I compiling the code, the CallProgRam is located in 00FACCH
00FACCH CallProgRam LABEL --- RAMPRO ?PR?PROGG
The problem that I found is when I'd like to load the program in target I've that message : No algorithme found for adress 0x00FACC.
There's any body can help me
Thanks.
Application note 138 explains how to link code to FLASH then copy and execute it in RAM.
http://www.keil.com/appnotes/docs/apnt_138.asp
