I'm trying to implement states for a dynamic menu that's being drawn on my LCD. From my understanding, in the main block, we need an infinite loop to run commands. I am trying to call a drawMenuBars() function, which also contains another while(!nextScreen) loop that will not break until nextScreen goes high.
For some reason my LCD screen goes all funky as if a whole bunch of hex codes are being sent. I can only assume this is because there are 2 while loops. I want to stay in the drawMenuBars function until next is pressed, but it seems like I can't have more than one infinite loop. Can someone tell me how to get around this issue so I can implement states pending where a user is?
how can anybody help you when you refer to vague functions like 'drawMenuBars' without any explanation? please post code snippets and provide more details.
I was hoping for someone to just tell me whether I could have an infinite loop in my main block as well as an infinite loop in a function to maintain a state. If you insist to see my code here it is.
main.c
/******************************************************************************* ** Main Function main() *******************************************************************************/ int main (void) { int boot = 0; // int menuState = 0; // Used to determine which menu bar is highlighted /* Initialize interfaces */ ledInit(); buttonInit(); i2cInit(); /* Main Loop */ while(1){ if(boot == 0) { drawBootScreen(); boot = 1; } if(nextButtonPressed()) drawMenuScreen(); } }
drawMenuScreen()
// Draws the menu bars after boot screen void drawMenuScreen(void) { u08 clear[2] = {0xfe,0x58}; int nextPos = 0; // Next menu bar position int menuState = 0; // Tells which menu is highlighted u08* text = "hi"; u08 reset[2] = {0xfe,0x48}; int next = 0; // Boolean that tells if next is pressed // int menu = 0; // Menu tracker to determine which bar to highlight i2cMasterSendNI(TW_MR_DATA_ACK, 0x02, clear); drawTitleBar(); while(!next) { /* while(menuState==0) { nextPos = drawMenuBox(0,10,"Start New Workout",1); if(downButtonPressed()) { nextPos = drawMenuBox(0,10,"Start New Workout",0); menuState = 1; } if(nextButtonPressed()) next = 1; } */ nextPos = drawMenuBox(0,10,"Start New Workout",1); nextPos = drawMenuBox(0,nextPos,"Resume Workout",0); nextPos = drawMenuBox(0,nextPos,"Connect to PC",0); nextPos = drawMenuBox(0,nextPos,"Settings",0); nextPos = drawMenuBox(0,nextPos,"History",0); if(downButtonPressed()) next =1; } i2cMasterSendNI(TW_MR_DATA_ACK,0x02,clear); }
drawMenuBox function
// Draw menu box with top left corner at (x,y) w or w/o shading int drawMenuBox(int x, int y, char* text, int shading) { u08 x1 = intToHex(x); u08 y_box = intToHex(y); u08 y_text = intToHex(y+2); u08 y2 = intToHex(y + MENU_BAR_HEIGHT); int nextYcoord = y + MENU_BAR_HEIGHT; u08 len = intToHex(strlen(text)); u08 cmd1[7] = {0xfe,0x78,0x01,0x00,0x00,0xfe,0x13}; // Draw box u08 cmd2[4] = {0xfe,0x79,0x00,0x00}; // Move cursor to (x,y) u08* cmd3 = (u08*)text; u08 cmd4[2] = {0xfe,0x48}; if(shading == 1) { cmd1[2] = 0x01; cmd1[3] = x1; cmd1[4] = y_box; cmd1[6] = y2; cmd2[2] = x1; cmd2[3] = y_text; } else { cmd1[2] = 0x00; cmd1[3] = x1; cmd1[4] = y_box; cmd1[6] = y2; cmd2[2] = x1; cmd2[3] = y_text; } i2cMasterSendNI(TW_MR_DATA_ACK, 0x7, cmd1); i2cMasterSendNI(0x50, 0x4, cmd2); i2cMasterSendNI(TW_MR_DATA_ACK, len, cmd3); i2cMasterSendNI(TW_MR_DATA_ACK, 0x02, cmd4); return nextYcoord; }
drawTitleBar function
// Draws the title bar displaying battery life(***Not yet implemented***) and cFit header void drawTitleBar(void) { u08 cmd1[6] = {0xfe,0x6c,0x00,0x09,0xfe,0x09}; // Draw line across y=9 u08 cmd2[4] = {0xfe,0x79,0x70,0x00}; // Move cursor to (0,124) u08* cmd3 = "cFit"; // Write to screen u08 cmd4[7] = {0xfe,0x78,0x01,0xe3,0x01,0xed,0x05}; // Draw battery box u08 cmd5[7] = {0xfe,0x78,0x01,0xed,0x02,0xef,0x04}; // Draw battery tip i2cMasterSendNI(TW_MR_DATA_ACK, 0x06, cmd1); i2cMasterSendNI(TW_MR_DATA_ACK, 0x04, cmd2); i2cMasterSendNI(TW_MR_DATA_ACK, 0x04, cmd3); i2cMasterSendNI(TW_MR_DATA_ACK, 0x07, cmd4); i2cMasterSendNI(TW_MR_DATA_ACK, 0x07, cmd5); }
I have tried running one command in the drawMenuScreen() loop. If drawTitleBar() is inside the loop it works. If I call a drawMenuBar the command is called multiple times but it is not drawing in the right place. I have a feeling it has something to do with the LCD more than the ARM7's functionality, and that one of my commands causes the x,y coordinates to change.
N/m I just needed to put a delay after a button signal goes high because the clock cycle is so fast.
