Hi, I am trying to generate an interrupt on GPIO pin for LPC2364 uc over uVision3 simulator. Below is the code written to achieve the job. I am not able to generate interrupt by toggling the GPIO pin. Is there anything wrong/missing in the code? Or is there any known bug in the simulator for this uc?
GPIO pin I am trying is: P0.16 (port 0, pin 16). Code:
void int_gpio (void) __irq {
cnt++;
IO0_INT_CLR |= (1<<16); /* clear the interrupt */
VICVectAddr = 0; /* ACK the VIC */
void task1 (void) __task {
/* On RESET, all GPIO pins are set as Input, PINSEL set to GPIO pins by default */
IO0_INT_EN_F |= (1<<16); /* enable falling edge interrupt for P0:16 */
VICVectAddr17 = (U32) int_gpio; /* EINT-3 interrupt handler */
VICIntEnable |= (1<<17); /* Enable VIC index-17 (shared by EINT3 and GPIO) */
os_tsk_delete_self(); /* task no more needed, can be killed */
You need the latest simulator which supports GPIO Interrupts in LPC23xx/24xx. Please contact support.intl@keil.com
