I have encountered some problems while writing the code for 8051 microcontroller, Can you explain me the following issues: 1- Compiler issued an error when i pass the value to function by referece e.g. void function( unsigned char& val);
2- Comiler issued an error when i tried to use the default argment to a function e.g. unsigned char Volume ( char side = 1 );
3- Comiler also issued error when i tried the function overloading method e.g. void function (unsigned char val); void function (unsigned int val);
4- How can i access variables with the same name which are both declerad local and global? Can anyone tell me above mentioned issue with keil comiler.
Regards, Ahmad Kamal Nasir
Are you programming in C or in C++? They are two completely separate languages, even if they may look quite similar.
I am programming in c ( using C51 compiler, evaluation version) for AT89C51 Microcontroller from keil.
looks like you're using (or trying to use) facilities of C++ in a C environment.
ANSI C does not support passing by reference
ANSI C does not support default arguments
ANSI C does not support function overloading
"How can i access variables with the same name which are both declerad local and global"
You can't - you have to give them different names!
What would be the point of having different variables with the same name, anyhow, if they need to be simultaneously accessible?!
After many years of 'figuring it out' I have started a practice that all local variables start with a (capitalized) 3 letter abbreviation of the function name.
This is the result of sometimes, after a global search on e.g. 'index', finding myself looking at 'index' in another function than the one I am interested in.
.... a frustrated "PC programmer" trying to make the poor little '51 'behave'.
Sir, as said so often before the '51 ain't no PC
Many 'habits' and 'practices' from "general C programming" will destroy the efficiency (and maybe even the functionality) of a '51 project.
The belief that if you can do C (which it seems you can not) you can just do a '51 without any study and changes of method is the ultimate falsehood.
PS once I were asked to help some PC types with code banking, I threw out their "excellent standard code" and recoded the project. What required banking when done "the PC way" occupied 4k when done "the '51 way"
Well, I think you're barking up the wrong tree. The "problems" have nothing to do with '51s or PC, but with trying to feed C++ code to a C compiler.
The "problems" .... trying to feed C++ code to a C compiler
Is that not "trying to make the poor little '51 [tools] 'behave'." ?
A C (not C++) compiler on the PC (or any other platform) will misbehave the same way when you're trying to use it to compile C++ code.
As Christoph says, it is not necessarily the case.
I don't think that any of the things mentioned would necessarily be particularly bad for a 51.
Of course, the fact that the OP hadn't even realised that there's a difference between C and C++ doesn't bode well for his having thought carefully about effeciency of programming on an 8051...
"A C (not C++) compiler on the PC (or any other platform) will misbehave (sic) the same way when you're trying to use it to compile C++ code."
It's not mis-behaving at all - it is behaving perfectly correctly!
.... a frustrated "PC programmer" trying to make the poor little '51 'behave'. Sir, as said so often before the '51 ain't no PC
the thing is that ever so often some "PC type" decides that doing the '51 is no different than doing a PC.
The results are, most often (always?) a total mess
how many posts have we not seen about malloc, function pointers etc.
Yes, all is possible, but NOT till you understand the underlying logic which "a 'PC type' doing the '51" does not.
that the OP does not even know that C is not C++ just emphasizes the point.
