LPC2364 GPIO Interrupt Problem
Hello all, I am trying to use a falling edge GPIO interrupt on P0.11.
I setup the pin as an input and have tested it as such and it seems to work fine.
PINSEL0 &= 0xFF3FFFFF;
PINMODE0 &= 0xFFBFFFFF;
// Set the pins to be GPIO inputs.
FIO0DIR1 &= 0xF7; // 11110111
I also setup the IO0_INT_EN_F to enable the falling edge interrupt.
IO0_INT_EN_F &= 0x800;
Also then load and enable the VIC channel. I see in the docs that EINT3 - channel 17 - is shared with GPIO interrupts.
VICVectAddr17 = (uint32)eint3_int;
VICIntEnable = (1 << 17);
Inside eint3_int I toggle an LED, clear the interrupt flag, and clear the VIC address register.
When I put a signal on P0.11 I never get any interrupt out of it. Signal looks good, 100us square pulse.
I threw a test bit of code to set the soft int in another timer routine - when I have a breakpoint in my ISR I repeatedly hit it as expected, but never with just the signal.
I am wondering if anyone else has used a GPIO interrupt in this fashion and had success? I can't find anything relating to this problem with the LPC23xx - but there are some issues for the other LPC21/22xx series having to do with order, etc. Could one of these things be an issue here as well?
Thanks in advance for any advice on this issue.
