I have written a program that writes into the Ethernet RAM of LPC2378. The Ethernet module is powered on using PCONP resiger. When ever i try to write anything to this RAM Area i am getting the error-
"Data Abort: ARM Instruction at 000010B8H, Memory Access at 7FE00000H "
I can also cannot change values in the Memory Window of the µVision Debugger.
I am using Keilb µVision 3 Debugger. The code is - ###################################################### u8 ERAMWrite(u32 ulAddress,u8 *ucData,u16 usLen) { unsigned char *ramarea= (unsigned char *)0x7FE00000; unsigned long *PCONP=(unsigned long *)0xE01FC0C4; //Power On Ethernet Device ramarea+=ulAddress; *PCONP|=(1<<30); if((ulAddress < 16384)) //16K Ethernet RAM { memcpy(ramarea,ucData,usLen); return(usLen); } else { return(0); } } ######################################################
Any help in this regard is highly awaited. Regards Som Appu
I assume that you are using the simulator.
Access to LPC23xx/24xx Ethernet RAM has been added recently in the simulator and will be part of the next release of MDK.
If you need a update please contact support.intl@keil.com.
