Variables that overlap in the same memory space possible?
Currently I have a set of structures represented as variables such as:
MYTYPE xdata A;
MYTYPE xdata B;
MYTYPE xdata C;
MYTYPE xdata D;
MYTYPE xdata E;
MYTYPE xdata F;
MYTYPE xdata G;
MYTYPE xdata H;
unfortunately E and G happen to not be used in this version of the software. Is it possible to force E and G to exist in the same space as F (for example)? Abusing the _at_ keyword seemed an exercise in futility (of COURSE it gives an error because you need a constant location that's an int for the compiler).
Any suggestions?
To answer WHY (which I'm sure was asked instantly) it's a matter of only having 1K of xdata space. This of course doesn't solve the issue if one needs to have ALL the variables. I'm just seeing what I can do without making a worse mess.
Thanks for listening (gritting teeth maybe?)
Stephen
