hello
i am trying to work with the serial port but i don't know which of the instruction had echo or not i am programing in C with the libary i am using is stdio.h how can i find out which of them had echo or not ??
output to the serial port : putchar puts printf
(there is echo at all when i sending out to the serial port ?!?!?)
input to the serial port : _getkey getchar gets scanf
thanks in advance mayer
You can look in the compiler Manual - it will tell you where to find the source for these functions.
Then you can inspect the source, and modify it if required...
Echo is something performed by the receiving side. If you send the data to a modem, then the modem may echo back your data. However, no transmit functions can echo any data.
thanks for the answer
that what i thoght
there is no problem with the instruction
putchar puts printf
mayer
