I am a newbie user to A51. Can anyone suggest a way to resolve the reported "OVERLAP" conflict caused by the source code listed below which uses Absolute addresses 0x00 - 0x07 that are obviously shared (pre assigned by A51) in Register Bank 0?
In the Timer 0 Interupt, I use the registers (R0-R7) after switching the Register Bank to 0. In the rest of the program, I use the Labels to directly access the memory locations (ie MOV SWTPNTR,#80H ).
The only way I can think to do it is to remove the Labels (and therefore the EQU statements) and have to switch back and forth from Reg Bank to Reg Bank every time I wish to MOV data to the absolute locations. Which would use a lot of excess coding.
Can anyone suggest another way to preserve the absolute labeling for DIRECT addressing them?
BTW, I am using all 4 Reg Banks the same way. The conflict is only reported for addresses 0x00 - 0x07. And this issue has never appeared when using other MCS-51 assemblers.
Thanks.
DSEG ; INDICATE INTERNAL DATA MEMORY SPACE ; ; *** REGISTER BANK 0 *** ; USED BY TIMER 0 ; EQU 00H ; R0 LAMP TABLE POINTER SWTPNTR EQU 01H ; R1 SWTABLE POINTER STROBE EQU 02H ; R2 CURRENT STROBE ; EQU 03H ; R3 COUNTER EQU 04H ; R4 PWVALUE EQU 05H ; R5 DESIRED LAMP INTESITY 00=OFF ; EQU 06H ; R6 ; EQU 07H ; R7 ; *** REGISTER BANK 1 *** ; USED BY TIMER 1
Found the solution: A51 DIRECTIVE: $NOREGISTERBANK Releases the memory reserved for registers.
