Memory addressing problem with ez-usb (CY7C68013a)
I have written the simple program as follows..
 BYTE xdata u_buf1[1]         _AT_  0x4001;
 BYTE xdata u_buf[1]           _AT_ 0x4000;
void main(){
        int val;
        OEB=0xFF;
   u_buf[3]="a,b";
   u_buf1[3]="c,d";
     while(1){
        IOB=u_buf1[1];
I keil debugger memory window it is showing that both of variabls u_buf[1] and u_buf1[1] is storing at location X:0x0000.
Whether i assigned them different location.
and junk valu is displaying at 0x0000 location.
  • _AT_ is not a Keil keyword, so you must have defined it yourself.
    Show your definition!
    Also, what do you intend by these lines of code:
       u_buf[3]="a,b";
       u_buf1[3]="c,d";
  • Here _AT_ is #defined as _at_ .
    so it's ok it is not showing any error.
    secondly..my memory map is some thing like this as follows.. www.cypress.com/.../server.pt
    You can download Ez-usb technical reference manual from above link..
    refer page number-84 fig-5.2
    here i intend to store a array in external memory location 0x4000.
    so i am using _at_ to do that.
    the following declaration
    XBYTE[0X4000]=0X55;
    XBYTE[0XE000]=0XAA;
    stores 0x55 in external memory location(xdata) 0x4000
    and
    stores 0xAA in external location (xdata) 0xE000.
    but i am not able to access it while storing a array at that location.
    Please help me out...
  • It really doesn't help to format your entire post as Bold, does it?
    You still haven't explained what you intend this code to do:
    u_buf[3]="a,b";
    u_buf1[3]="c,d";
    You cannot simply assign strings in 'C' like that - see your 'C' textbook!
