Problem with DSP XC166Lib
Hi!
I have a problem with compile *.c files comprising CoMOV and other Co asm instructions...
Compiler control string
MODV2 HCOMPACT BROWSE UNSIGNED_CHAR INCDIR(.\inc\;.\inc\uc_GUI\) DEBUG PRINT(.\lst\*.lst) TABS (2) PREPRINT(.\lst\*.i)
ERROR
src\DSP\Fir_16.c(71): error C195: inline-asm: invalid expression token
When I add
#pragma MAC
directive in top of file nothing changes, also in C166 Misc control string.
When I add
#pragma EXTMAC
ERROR
  ERROR:   RESPECIFIED OR CONFLICTING CONTROL
PLEASE HELP ME!
Listing of *.c file
#include "DspLib_Keil.h"
DataS Fir_16(DataS* H, DataS* IN, DataS N_h, DataS* D_buffer)
   __asm
;MAC registers initialization
        MOV             MCW,#0600h              ; MP=1, MS=1
        SUB             N_h,#2h                 ; N_h-2
        MOV             MRW,N_h                 ;(MRW)=N_h-2, repeat count
;ESFR register initialization
    ADD         N_h,#1                  ;(R14)=N_h-1
        SHL             N_h,#1                  ;(R14)=2*(N_h-1)
        EXTR    #3                              ; Next 3 instructions use ESFR space
        MOV             IDX0,D_buffer   ;(IDX0)=DPRAM_add
        MOV             QX0,N_h                 ;(QX0)=2*(N_h-1)
        MOV             QR0,N_h
;Read the new input sample and move it
;at x(n-1) address overwriting x(n-1)
        CoMOV   [IDX0],[IN]                                     ;x(n-1) <- IN
        CoNOP   [IDX0+QX0],[H+QR0]                      ;return the pointers to beginning
;FIR: first multiplication, h(N_h-1)*x((n-N_h+1)
        CoMUL   [IDX0-],[H-]            ;(ACC)=h(N_h-1)*x(n-N_h+1)<<1
        ;(IDX0)=(IDX0)-2
        ;(R12)=(R12)-2
;FIR loop: repeat N_h-1 times the same MAC instruction
loop1:                                                          ;i=(N_h-2):(-1):0
-USR1   CoMACM  [IDX0-],[H-]            ;(ACC)=(ACC)+h(i)*x(n-i)<<1
        ;x(n-i-1) <- x(n-i)
        ;(IDX0)=(IDX0)-2
        ;(R12)=(R12)-2
                JMPA    cc_nusr1,loop1
        CoNOP   [IDX0+],[H+]
;Rounding
        CoRND
;wirte the 16-bit filter output y(n) into registers R4
    CoSTORE     R4,MAH          ;(R4)=(MAH)
  • Hello,
    In uVision IDE, "Projects" menu, look at "Options for Target..." ---> tab "C166" ---> "Misc Controls" and put EXTMAC in there. It works for me:
    IDE-Version:
    µVision3 V3.21
    Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2005
    Tool Version Numbers:
    EC++ Compiler:      EC166.Exe      V1.09
    C Compiler:         C166.Exe       V6.02
    Assembler:          A166.Exe       V5.20
    Linker/Locator:     L166.Exe       V5.21
    Librarian:          LIB166.Exe     V4.26
    Hex Converter:      OH166.Exe      V4.7a
    CPU DLL:            S166.DLL       V2.49
    Dialog DLL:         D167.DLL       V2.45
    Target DLL:         MONITOR\MON166.DLL       V2.41
    Dialog DLL:         T167.DLL       V2.45
    Also, see my post at http://www.keil.com/forum/docs/thread9986.asp
    Regards,
    Nikolay.
  • Thanks Nikolay!
    Really, my code was succesfully compiled by 6.06 version of C166 compiler.
    IDE-Version:
    µVision3 V3.50
    Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2007
    EC++ Compiler:      EC166.Exe       V1.09b
    C Compiler:         C166.Exe       V6.06
    Assembler:          A166.Exe       V5.21
    Linker/Locator:     L166.Exe       V5.22
    CPU DLL:            S166.DLL       V2.52
    Dialog DLL:         D167.DLL       V2.48
    Target DLL:         BIN\UL2OCDS.DLL       V1.12
    Dialog DLL:         T167.DLL       V2.48
    But C166 4.27 doesn't compile same code :)
  • Hello Nikolay!
    I have still problem.
    I compile & link my main program in old Keil version with C166 v.4.27. (license ver.)
    But this version of compiler does not support inline asm with MAC.
    I attempted to make library in 6.06 restricted demo version... but when I attempt link this library in 4.27 version...
    *** FATAL ERROR L251: RESTRICTED MODUL IN LIBRARY NOT SUPPORTED
    Can you make library in full version of C166 upwards of 5.00 for me?
    mailto:legotron@mail.ru
    C166 Version 5.00 Release
    [MAC Programming: Example Code for Signal Processing]
    The DSP Library from Infineon (using in-line assembly for MAC programming) is now available.
    Thanks!
