I am using the ADuc814 microntroller and I'm trying to use the SPIs' ISR. It is currently not jumping to the ISR. For this microcontroller, the interupt vector address is located at 0x3Bh, which means that I should use interrupt 7. The SPI appears to be in operation because I put a couple of test lines in the main function of the program that sits in a while loop until the ISPI bit is set. Once that occurs I configured a LED to come on. When I ran that little test program the LED came on, so I know that the SPI is recieving the data. To me the problem appears to be jumping to the ISR when the ISPI bit is set. I have the code related to the SPI ISR below. I will be using one timer interupt in the final program as well, but I presently have it turned off until I can get the SPI interupt working. Any help/direction will be greatly appreciated.
main{ ...much more code is in this function, but I only included what pertains to the SPI.... CFG814 = CFG814 | 0x01; /*set bit 0 for SPI*/ SPICON = SPICON | 0x2C; /*SPI settings, slave, clk idles high, trailing clk edge transmits data*/ EA = 1; } void spi_isr (void) interrupt 7 { ....At this point, I simply tried having an LED come on and it does not.... }
I do not know the ADuC, but most uCs I know can (with nominal modifications) use the code generated by the CodeArchitect for lpc 935, free from http://www.esacademy.com.
Alan,
My guess (and it's just a guess): You're not setting the interrupt enable bit for this interrupt. The ISPI bit cannot actually vector to an interrupt until its allowed to do so. The "EA" bit that you set in the interrupt-enable register enables the interrupt system in general, but there will also be a SPECIFIC bit in IE (or something similar) that allows the particular flag bit generate an interrupt.
Taking a look at the datasheet for the ADuC814, I'd say add the following line before setting EA:
IEIP2 |= 0x01;
and bob is, as they say, your uncle.
-Jay Daniel
Jay,
You were correct in your guess. Thanks for the help.
Alan
