When I used the IENABLE and IDISABLE routines in Keil CARM compiler it all worked fine. Now I'm using Keil realview and suddenly I get some strange errors when I compile my code.
error: #20: identifier "LR" is undefined error: #20: identifier "SP" is undefined
I also tried some routines from NXP (see below). These compiled ok but I think something is missing in the routines because the program crashes when I use them for nesting interrupts.
Can someone tell me how to make these routines work in Realview?
Kind regards, Sander
/* routines from KEIL */ #define IENABLE \ __asm { MRS LR, SPSR } \ __asm { STMFD SP!, {LR} } \ __asm { MSR CPSR_c, #0x1F } \ __asm { STMFD R15!, {LR} } \
#define IDISABLE \ __asm { LDMFD SP!, {LR} } \ __asm { MSR CPSR_c, #0x92 } \ __asm { LDMFD SP!, {LR} } \ __asm { MSR SPSR_cxsf, LR } \
/* routines from NXP */ static uint32 sysreg; /* used as LR register */ #define IENABLE __asm { MRS sysreg, SPSR; MSR CPSR_c, #SYS32Mode; STMFD SP!, {sysreg} }
#define IDISABLE __asm { MSR CPSR_c, #(IRQ32Mode|I_Bit); MSR SPSR_cxsf, sysreg }
again no support from Keil?!
Where you expecting support from Keil on this forum?
This is not a support forum. This is a forum for end-users of Keil products.
If you want support from Keil, please contact their support!
Well I was hoping for some support from anyone.
