HI
I have writen the next file,but it's wrong! In the source group 1,there are three flies:test.c, START900.A51 and C51S.LIB. why.....? //file name:test.c #ifdef ASM unsigned long shiftR1(register unsigned long); #else extern unsigned long shiftR1(register unsigned long); #endif #define ASM #include<asm.h> #include <Reg936.h> void delay02s(acd) { #pragma ASM abcd: mov r6,#40 abcc: mov r5,#255 djnz r5,$ djnz r6,abcc djnz r7,abcd #pragma ENDASM }
void main( void) { unsigned char ab,acd; P0M1=0xff; P0M2=0xff; ab=1; acd=128; while(1) { if(ab==128) { P0=~acd; ab=128; acd/=2; delay02s(acd); } if(acd==128) { P0=~ab; acd=128; ab*=2; delay02s(ab/2); } if((ab==128)&&(acd==1)) { ab=1; acd=128; } } } How can I program ASM in C,or include other .asm programme or files?
So you saw how to use the Bold and Italic tags, but didn't bother to use the 'pre' and '/pre' tags to post your code!
Please re-post the code using those tags so that it's legible. Remember to use copy-and-paste; do not manually re-type it into the forum!
Why do you want ASM in a 'C' file? It is generally a bad idea, based on unfounded assumptions about and/or ignorance of how the compiler works.
It is generally far better to write a separate assembler function in a separate assembler file and just call that function from 'C'
See, for example: http://www.keil.com/forum/docs/thread9558.asp
See also: http://www.keil.com/support/man/docs/c51/c51_ap_ctoasm.htm
http://www.keil.com/forum/docs/thread10015.asp
Don't keep starting new threads - if it's the same subject, then keep to the same thread and use the 'Reply' button...
Nice to get your replying! Thanks your warm heart and your messages! I will corret it.
