HI
i need the circuit diagram of MAX 232 connection with 89C51 .Actually i want 89C51 TO COMMUNICATE serially with computer..PLZ help me out
There are litterally thousands and thousands of examples of how to use a MAX232 directly available on the net. Have you spent any time looking for information?
Have you checked for schematics for sample boards that makes use of the 89C51? A serial port is so basic that all evaluation boards has serial port support!
I have the MAX 232 pin connection diagram and 89C51 MC but i need the whole connection which pins from MC connected to MAX232 and from MAX 232 which are connected to serial port
Since you not only are missing the information how to connect the 89C51 to the MAX232 but also how to connect the MAX232 to a D-Sub connector, you most definitely haven't spent a single minute looking for information yourself.
Finding out how to connect the 89C51 to the MAX232 shouldn't take many minutes more.
Unless you don't fancy google and wants someone else to google for you. Are you into distributed computing?
I strongly susupect that every Keil board features a MAX232 (or equivalent)...
http://www.keil.com/boards/
OK dude give me your e-mail id i am sending you the circuit diagram and tell me whether it is correct or wrong i hope you just stop talking and give me some help some sites name some circuit dig my email is givenchyl_05@yahoo.com
Google Says: www.pjrc.com/.../hardware.html
So now that you have it, do you understand it?
The connections of the capacitors are as shown in the Datasheet;
The logic-level transmit output from the 89C51 connects to the logic-level input of a transmitter in the MAX232;
The output of a transmitter in the MAX232 is RS232 - so that connects to the appropriate pin on your RS232 connector ('D'-type);
The input of a receiver in the MAX232 is RS232 - so that connects to the appropriate pin on your RS232 connector ('D'-type);
The logic-level output of a receiver in the MAX232 connects to the logic-level receive input of the 89C51.
It's really not rocket science!
DUDE i am trying to watch the result on hyper terminal can u send me any prog in assembley
1) I need the schema to a ... 2) Can you send me any prog ... 3) Can you come and solder together the unit? 4) Can you come and flash my processor? 5) Can you write my report, so I can turn it in?
Per:
you forgot DUDE:
trevlig helg
Ah, but I did look for earlier posts in the thread, but didn't find anyone named DUDE. However, it made me think about John Wayne - Duke.
Trevlig helg sjaelv!
(This forum doesn't support UTF-8 even if the encoding says UTF-8...)
Behold the future of engineering. Cheap, but clueless.
"can u send me any prog in assembley"
What - any program?
Sure - here is something in some assembler:
ProgStart: call _flushallmenus call _runindicoff LoadRoutine: ld hl,RoutineStart ld de,_alt_on_exec ld bc,200 ld de,$28 ld a,(_alt_on_exec) ld hl,_alt_on_chksum + $28 add a,(hl) add hl,de add a,(hl) add hl,de add a,(hl) add hl,de add a,(hl) add hl,de add a,(hl) ld (_alt_on_chksum),a set 3,(iy + $23) ret RoutineStart: .org _alt_on_exec in a,(5) push af ld a,$0d out (5),a call _clrScrn call _homeup ld hl,TextToDisplay call _puts call _newline pop af out (5),a ret
