connect reset pin µC with reset-pin from ext. flash
Is it a good way or important (necessary) to connect the reset pin from the external flash with the reset pin from the microcontroller?
e.g. if you program your external flash via jtag?
Or is it also possible to connect the reset pin to one of the I/O-pins from the microcontroller?
best regards
CJendsen
