RTX166Tiny & EC++ have problem!
Good day!
I have a problem with using RTX166 Tiny OS with EC++.
If I try to define tasks in .cpp file, I dont see JUMP to _main() function.
In technical support:
"RTX166 TINY: CAN'T DEFINE TASKS IN EC++"
http://www.keil.com/support/docs/2812.htm
advises to "Simply define your _task_ and interrupt functions in a .C file".
In this case Can I use C++ features (ex. define objects) in tasks functions?
In file C:\Program Files\Keil\C166\Rtx_Tiny\readme5.txt I have read following note:
Function os_start for EC++ compatiblity
The function os_start enables the usage of RTX166 Tiny together with EC++. EC++
requires special initalizations that are performed in the main routine. After
this initalizations, the os_start function can be called to start the RTX166
Tiny kernel.
EXTERN_C void _main ()  {
  init_mempool (mempool, sizeof (mempool));  // create memory pool for new & delete
  __sti__init__ ();                          // call initializer functions
  os_start ();                               // start RTX166 kernel
But senselessly try to call os_start(), if _main() is not called.
P.S.
Problem "expected {" I resolve using replace _task_ with __task. Is it correct?
  • Oleg,
    I don't quite understand your problem, however there is one thing that strikes me in the code you posted: __sti_init__() does not return. Therefore your OS won't be initialized when you start using it (and I don't want to imagine what's going to happen then...)
    __sti_init__() initializes all your objects, virtual tables or what-have-you, and then it calls main().
    Therefore you should put os_init() in your main() function, not in _main().
    After the OS is initialized, then you can start creating tasks.
    You need to use the keyword __task instead of _task_ for tasks definitions in C++ files.
    I've been using EC++ and RTX Tiny and ARTX for quite a while and it works pretty well.
    $0.02
    Steph-
  • Ah, scratch that, __sti_init__() DOES return...
    Steph-
  • Stephane,
    You said:
    "Therefore you should put os_init() in your main() function, not in _main()"
    but where is the main() function situated?
    There is no main function in OS projects, only tasks!
    Now, I've placed _main() CALL explicitly in task 0.
    But I'm sure that it is not correct way, isn't it?
    the problem remains.
  • Oleg,
    Ignore my previous post, as it is confusing.
    Short answer: define a main() anyway, and see what happens.
    Long answer:
    There is an example in Keil\C166\Rtx_Tiny which is supposed to show how to use EC++ and RTX Tiny. It doesn't work on my machine! _main() is never called, I believe there is a problem with this example.
    It seems that RTX Tiny defines a symbol called main, which in turn calls os_start() (look at the source code for RTX Tiny)
    One workaround is to define, and it can by anywhere in your cpp code really:
    int main() {}
    This symbol will override the one in RTX Tiny's library, which means that this function will be called, rather than the one inside the real time library. Then, the EC++ parser will recognize this special function and call _main() automatically, as soon as main() is executed (look at how main() is modified inside the .ic. file)
    Other workaround: modify the .a66 initialization file so it calls _main instead of main. Look for the lines of code that say:
    EXTRN   main:Model
    $IF TINY
                    JMP     main
    $ELSE
                    JMP     FAR main
    $ENDIF
    and replace all main with _main.
    Not sure if this makes sense, but I hope this helps...
    -Stéphane
  • Take a look here: C:\Keil\C166\Examples\EC++\RtxTiny
    This example shows you how to create an RtxTiny Application with EC++.
    Reinhard
  • Hello Reinhard,
    This example seems to be broken (at least for me), that's the problem.
    _main() is never called, which is an issue because then EC++ classes are not initialized, neither is the memory pool...
    This example is so simple (no constructors, not even a single data member) that it appears to be working, whereas in fact the EC++ initialization is not done at all.
    -Stephane
