How to use RTL to calculate time?
I use RTL for LPC214x, and I want to test the time used for my own code, how can I do that with RTL?
Does RTL provide some function like GetTimeCount() in VC++?
  • No, it really does not.
    The "Easiest" way to do this would be add a u32 counter to the RTX_Config.c file in the os_chk_robin() function. (before the #if (OS_ROBIN == 1). increment this counter every time the os_chk_robin() function is called (which should be called on every OS Timer Tick, the rate you have set up in the RTX_Config.c File.
    u32 osTickCount;
    void os_chk_robin(void)
        osTickCount++;
    #if (OS_ROBIN == 1)
    #endif
    u32 getTickCount()
       u32 value;
       tsk_lock();
       value = osTickCount;
       tsk_unlock();
       return value;
