Again UART2 and UART3 - (not being simulated) - Help Needed
Dear All,
I found lots of threads regarding UART2 and UART3 for LPC2378
With keil simulator not working and , how to work around tom get resolve
This issue using PCONP and all that.
Still I have the same problem.
I am using Keil u-vision 3.11(evaluation version)
and MCB -2300 boards (for both 2368/78).
I have the same problem with both UART(2/3),
I am not getting data on simulator nor
On board (for board I have traced out UART2 lines to the MAX 232 IC as like UART1 on board), It might the separate issue,
but I think first I should able to get data of UART2
On simulator itself later on board.
I have setted up the PCONP register described on this site (as per LPC UM)
(I am able to see data of UART1 and UART2 on simulator on serial windows (UART#0, UART#1) respectively, also I am getting data on board on serial port, but not getting data of UARt2 and UART3)..
My code is as below …
/***** START CODE ***********************/
extern void initSerialAllUart (int BaudRate);
extern SendcharUart0(char);
extern SendcharUart1(char);
extern SendcharUart2(char);
extern SendcharUart3(char);
Main.c
Void Main(void)
{ int i;
PCONP |= 1 <<24 ; // Enable UART2
PCONP |= 1<<25; // Enable UART3
initSerialAllUart(9600); //init all uart for 9600 baudrate
for(i=0;i<50;i++) // send 50 character to all ports
SendcharUart0(65);
SendcharUart1(66);
SendcharUart2(67);
SendcharUart3(68);
/*End Main*/
serial.c
void initSerialAllUart (int BD) //Initialize Serial Interface
unsigned long Tp; //for baudrate calculation
PINSEL0 |= 0x00000050; //Select UART0-Tx,Rx PINSEL0 |= 0x40000000; //Select UART1-Tx PINSEL1 |= 0x00000001; //Select UART1-Rx PINSEL0 |= 0x00500000; //Select UART2-Tx,Rx PINSEL0|=0xA; //Select UART3-Tx,Rx
/*-----Init UART0 settings--------------*/
U0FDR = 0; /* Fractional divider not used */
U0LCR = 0x80;/* 8 bits, no Parity, 1 Stop bit*/
U0LCR = 0x03;/* DLAB = 0 */
Tp = ((14400000UL / 16UL) + (BD -1)) / BD;
U0LCR |= 0x80; /* Set DLAB */
U0DLL = Tp;
U0DLM = (Tp >> 8);
U0LCR &= ~0x80; /* Clear DLAB */
/*-------Init UART1settings-----------*/
U1FDR = 0; /* Fractional divider not used */
U1LCR = 0x80;/* 8 bits, no Parity, 1 Stop bit*/
U1LCR = 0x03; /* DLAB = 0 */
Tp = ((14400000UL / 16UL) + (BD-1)) / BD;
U1LCR |= 0x80; /* Set DLAB */
U1DLL = Tp;
U1DLM = (Tp >> 8);
U1LCR &= ~0x80; /* Clear DLAB */
/*-----Init UART2settings------------*/
U2FDR = 0;/* Fractional divider not used */
U2LCR = 0x80; /* 8 bits, no Parity, 1 Stop bit*/
U2LCR = 0x03; /* DLAB = 0*/
U2LCR |= 0x80; /* Set DLAB */
U2DLL = Tp;
U2DLM = (Tp >> 8);
U2LCR &= ~0x80; /* Clear DLAB */
/*--Init UART3settings-----------------*/
U3FDR = 0; /* Fractional divider not used */
U3LCR = 0x80; /* 8 bits, no Parity, 1 Stop it*/
U3LCR = 0x03; /* DLAB = 0*/
U3LCR |= 0x80; /* Set DLAB */
U3DLL = Tp;
U3DLM = (Tp >> 8);
U3LCR &= ~0x80; /* Clear DLAB */
int SendcharUart0 (int ch)
/* Write character to Uart0 */
while (!(U0LSR & 0x20));
return (U0THR = ch);
int SendcharUart1 (int ch)
{ /* Write character to Uart1 */
while (!(U1LSR & 0x20));
return (U1THR = ch);
int SendcharUart2 (int ch)
{ /* Write character to Uart2 */ while (!(U2LSR & 0x20));
return (U2THR = ch);
int SendcharUart3 (int ch)
{ /* Write character to Uart3 */
while (!(U3LSR & 0x20));
return (U3THR = ch);
/******END CODEs **************************/
Can anybody guide me, how to get data of UART2 and UART3 over simulator ?!
