i wrote about similiar problem http://www.keil.com/forum/docs/thread9546.asp
and now i have same problem i use odd adres memory (for example) and got problem text test progfam for ARM you may see
if used odd adres 0x801 i had problem if didnt use __packed if i used __packed i have no problem
IDE-Version: µVision3 V3.51 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2007 Tool Version Numbers: Toolchain Path: BIN30\ C Compiler: ARM/Thumb C/C++ Compiler, RVCT3.0 [Build 951] for uVision [Full] Assembler: ARM/Thumb Macro Assembler, RVCT3.0 [Build 951] for uVision [Full] Linker/Locator: ARM Linker, RVCT3.0 [Build 951] for uVision [Full] Librarian: ARM Archiver, RVCT3.0 [Build 951] for uVision Hex Converter: ARM FromELF, RVCT3.0 [Build 951] for uVision [Full] CPU DLL: SARM.DLL V3.05 Dialog DLL: DARMP.DLL V1.13b Target DLL: BIN\UL2ARM.DLL V1.26b Dialog DLL: TARMP.DLL V1.11f **************************************************************** command compiler if you want get the same result -c --device DARMP -g -O0 --apcs=interwork -I "C:\Keil\ARM\INC\Philips" -o "*.o" **************************************************************** int main() { volatile unsigned long work; #define reg0 ( *(volatile unsigned long __packed *)0x801) //#define reg0 ( *(volatile unsigned long *)0x801) work=reg0; } **************************************************************** #define reg0 ( *(volatile unsigned long *)0x801) 8: work=reg0; 9: 0x000001B0 E3A00001 MOV R0,#0x00000001 0x000001B4 E5901800 LDR R1,[R0,#0x0800] **************************************************************** #define reg0 ( *(volatile unsigned long __packed *)0x801) 8: work=reg0; 9: 0x000001B4 E59F0010 LDR R0,[PC,#0x0010] 0x000001B8 EB000004 BL 0x000001D0 0x000001BC E1A04000 MOV R4,R0 10: } 0x000001C0 E3A00000 MOV R0,#0x00000000 0x000001C4 E8BD4010 LDMIA R13!,{R4,R14} 0x000001C8 E12FFF1E BX R14 0x000001CC 00000801 DD 0x00000801 0x000001D0 E5D02001 LDRB R2,[R0,#0x0001] 0x000001D4 E5D01000 LDRB R1,[R0] 0x000001D8 E5D03002 LDRB R3,[R0,#0x0002] 0x000001DC E5D00003 LDRB R0,[R0,#0x0003] 0x000001E0 E1811402 ORR R1,R1,R2,LSL #8 0x000001E4 E1811803 ORR R1,R1,R3,LSL #16 0x000001E8 E1810C00 ORR R0,R1,R0,LSL #24 0x000001EC E12FFF1E BX R14
"i use odd adres memory (for example) and got problem"
I'll repeat what I said in the other thread:
"For whatever ARM you are using or simulating, read up on how it handles unaligned memory accesses."
