trouble over trouble
Hello
I'm working with the AT91RM9200 from Atmel and I have some problems with data abort. The stack size is big enough. I tested it by making the user stack size zero and see which errors now occured. Everything was overwritten by other things. At the moment my stack size is 0x00000200. The error which occured is that the ptr to the usart base address is overwritten either if the usart.o is stored in the internal ram or the external ram. I use the watch window to see if the ptr would change his value - but nothing happens. I only know that the value is changed because I set a dummy within the retarget function for printf() - (thanks for the hint Per).
The whole programm only includes the ethernet init part, the usart and retarget function in separate c-files. So I have one main file with only the main routine where I init all other functions by calling the right function. In the while loop (main.c) I only poll if a flag is set by receiving a new frame by the ethernet. This works with the data abort problems.
These problems don't appear always at the same part of code. Is my acceptance right, that if I would have a stack size problem, the error would occurred always at the same part of code?
When I test the whole programm several times, I have one or two passes where no error occured. Very often the error happened bevor I call the init function for the ethernet part. So I don't think there would be a error during the execution of the code. I think the error could / must be very global.
If I don't include the ethernet part, then I got no data abort error. But I'm not able to find the / or these problems.
the headerfile of the ethernet part:
#define AT91C_EMAC_TDLIST_BASE                     0x21000000                                              /* */
#define ETH_PACKET_SIZE                 1536                                            /* greater than 1518 or 1522 (VLAN) bytes */
#define NB_ETH_RX_PACKETS               10                                                              /* number of RX buffer */
#define EMAC_RXBUF_ADD_WRAP                             0x02                                                    /* WRAP Bit at the end of the list descriptor */
#define MII_STS_REG                                     0x01
#define MII_STS2_REG                                    0x11
#define RxPacket (AT91C_EMAC_TDLIST_BASE + (8 * NB_ETH_RX_PACKETS))
typedef struct {
     unsigned int   RxBufAddr;
     unsigned int   RxBufStatus;
} *EMAC_pRX_descriptor;
void Phy_Init(void);
  • and the c-file - maybe someone of you will find the problem.
    char localMACAddr[6] = {0x00, 0x05, 0xD2, 0xFA, 0xB0, 0x01};
    EMAC_pRX_descriptor p_rxBD = (EMAC_pRX_descriptor)AT91C_EMAC_TDLIST_BASE;
    void ethernet_interrupt(void) __irq
            unsigned int status;
            AT91PS_EMAC pEmac = AT91C_BASE_EMAC;
            // clear receive status register
            status = pEmac->EMAC_ISR;
            if (status & AT91C_EMAC_RCOM)                               // Receive complete
                    Emac_Receive=1;
            if(status & AT91C_EMAC_ROVR)
                    overrun=1;
            AT91C_BASE_AIC->AIC_EOICR = 0;                               // End of ISR
    unsigned short AT91F_MII_ReadPhy(AT91PS_EMAC pEmac, unsigned char addr)
            unsigned int value = 0x60020000 | (addr << 18);
            pEmac->EMAC_MAN = value;
            // Wait until IDLE Bit in Network Status Register is cleared
            while (!(pEmac->EMAC_SR & AT91C_EMAC_IDLE));
            return (pEmac->EMAC_MAN & 0x0000ffff);
    int MII_GetLinkSpeed(AT91PS_EMAC pEmac)
            unsigned short stat1, stat2;
            stat1 = AT91F_MII_ReadPhy(pEmac, MII_STS_REG);
            stat2 = AT91F_MII_ReadPhy(pEmac, MII_STS2_REG);
        //set MII for 100BaseTX and Full Duplex
            if ((stat1 & 0x4000) && (stat2 & 0x8000) )
            pEmac->EMAC_CFG |= (AT91C_EMAC_SPD| AT91C_EMAC_FD);
        //set MII for 10BaseT and Full Duplex
            else if ((stat1 & 0x1000) && (stat2 & 0x2000))
            pEmac->EMAC_CFG = (pEmac->EMAC_CFG & AT91C_EMAC_SPD) | AT91C_EMAC_FD;
        //set MII for 100BaseTX and Half Duplex
            else if ((stat1 & 0x2000) && (stat2 & 0x4000))
            pEmac->EMAC_CFG = (pEmac->EMAC_CFG | AT91C_EMAC_SPD ) & ~AT91C_EMAC_FD;
        //set MII for 10BaseT and Half Duplex
            else if ((stat1 & 0x0800) && (stat2 & 0x1000))
            pEmac->EMAC_CFG = pEmac->EMAC_CFG & ~AT91C_EMAC_SPD & ~AT91C_EMAC_FD;
            return 0;
    int MDIO_StartupPhy(AT91PS_EMAC pEmac)
            int ret;
            //enable Management MDIO Port to read/write into the registers of the PHY
            pEmac->EMAC_CTL |= AT91C_EMAC_MPE;
            ret = MII_GetLinkSpeed(pEmac);
            ret = ret;
            //disable mdo
            pEmac->EMAC_CTL &= ~AT91C_EMAC_MPE;
            return 0;
    void Phy_Init(void)
            unsigned int i=0, status=0;
            char *pRxPacket =(char *)RxPacket;
            for(i=0; i< NB_ETH_RX_PACKETS; i++)
                    p_rxBD[i].RxBufAddr = (unsigned int)pRxPacket;
                    p_rxBD[i].RxBufStatus = 0;
                    pRxPacket +=ETH_PACKET_SIZE;
            //set wrap bit at the end of the list descriptor
            p_rxBD[NB_ETH_RX_PACKETS - 1].RxBufAddr |= EMAC_RXBUF_ADD_WRAP;
            //enable pmc
            AT91F_EMAC_CfgPMC();
            //enable MII ethernet pins peripheral
            AT91F_EMAC_CfgPIO();
            status = MDIO_StartupPhy(pEmac);
            status = status;
            // program the hardware MAC Address
            // the sequence write EMAC_SA1L and write EMAC_SA1H must be respected
            pEmac->EMAC_SA1L = ((int)localMACAddr[2] << 24) | ((int)localMACAddr[3] << 16) | ((int)localMACAddr[4] << 8) | localMACAddr[5];
            pEmac->EMAC_SA1H = ((int)localMACAddr[0] << 8) | localMACAddr[1];
            //receive buffer queue pointer
            pEmac->EMAC_RBQP = (unsigned int) p_rxBD;
            // clear status register
            pEmac->EMAC_CTL  = 0;
            // RMII enable
            pEmac->EMAC_CFG  = (pEmac->EMAC_CFG & ~(AT91C_EMAC_CLK)) | AT91C_EMAC_CLK_HCLK_32
                                                    | AT91C_EMAC_CAF | AT91C_EMAC_RMII |AT91C_EMAC_BIG;
            //clear receive status register (overrun, received frames e.g)
            pEmac->EMAC_RSR  &= ~(AT91C_EMAC_OVR | AT91C_EMAC_REC | AT91C_EMAC_BNA);
            // enable MAC interrupts   (kein AT91C_EMAC_DONE)
            pEmac->EMAC_IER |= (AT91C_EMAC_RCOM | AT91C_EMAC_RBNA | AT91C_EMAC_OVR
                            | AT91C_EMAC_TUND | AT91C_EMAC_RTRY | AT91C_EMAC_TCOM
                            | AT91C_EMAC_ROVR | AT91C_EMAC_HRESP | AT91C_EMAC_LINK);
            //AIC interrupts
            AT91F_AIC_ConfigureIt(AT91C_BASE_AIC,
                                                            AT91C_ID_EMAC,
                                                            AT91C_AIC_PRIOR_HIGHEST - 3,
                                                            AT91C_AIC_SRCTYPE_EXT_HIGH_LEVEL,
                                                            (void (*) (void))ethernet_interrupt);
            AT91F_AIC_EnableIt( AT91C_BASE_AIC, AT91C_ID_EMAC);
            //enable transmit and receive
            pEmac->EMAC_CTL  |= (AT91C_EMAC_TE | AT91C_EMAC_RE);
    I install the startup in the external flash memory
    *.o (RESET, +First)
                    *(InRoot$$Sections)
                    .ANY (+RO)
    the RW and ZI data from the ethernet part is stored in the external RAM and all other data are stored in the internal RAM
    .ANY(+RW +ZI)
    It would be very nice, if you could help me with my big problems..
    Johannes
  • I made a big step - I have erased the whole code in the phy_init.c file until one global variable and one function where I changed the value of this global variable.
    From the main.c routine I called this function and get the same error. So the code must be right, the stack size is big enough, the only thing which is different is that this c-file will be stored in the external sdram.
    If I take a look into the map file everything looks good to me.
    Execution Region SDRAM (Base: 0x20000000, Size: 0x00000004, Max: 0x03ffffff, ABSOLUTE)
        Base Addr    Size         Type   Attr      Idx    E Section Name        Object
        0x20000000   0x00000004   Data   RW           88    .data               phy_init.o
    What could be the problem - hardware problem with the sdram? or the wrong frequency or 'Number of Wait states?
    Which values do I have to check to solve this problem?
    Johannes
  • Which values do I have to check to solve this problem?
    First, you could check the abort status. See 16.3.4. in the chip documentation (that's on page 124 in the copy I have). It will tell you what address the MCU was trying to access when the abort occurred.
  • How can I do that, because if a data abort occured, then I'm not able to do anything...
    And after I restart the processor both registers are 0x00000000.
    Johannes
  • ok my ASR register is: 0x00010202 and my AASR register is 0x10000b69
    when I look into the map file then I found:
    local symbols:
     _printf_core                             0x100008bd   Thumb Code  1132  printf8.o(i._printf_core)
        i._printf_post_padding                   0x10000d28   Section       38  printf8.o(i._printf_post_padding)
    or global symobls
     __scatterload_zeroinit                   0x100008a4   ARM Code      24  handlers.o(i.__scatterload_zeroinit)
        Region$$Table$$Base                      0x10000d80   Number         0  anon$$obj.o(Region$$Table)
    the ASR register:
    - misaligned address abort status
    - code fetch
    - the last aborted access was due to the ARM920T
    that are all information. So the data abort comes from the printf() function - but why?
    Johannes
  • most errors occured within the stack - below the stack pointer and sometimes I have errors above the stack pointer (but most of the time in the internal RAM - only one error was in the external sdram (during 20 tries)... Moreover I only get the data aborts if packets were received by the ethernet, but these packets don't use any kind of internal sram, because they are stored in the sdram by the DMA.
    best regards
    Johannes
  • Have you looked at the overwritten memory area - is there a pattern to the data there? Have you tried to send ethernet packets with specific test data?
    You say that the ethernet packets are stored in the sdram. But have you verified that you actually get data there? For example by filling the sdram area with a pattern so you can see that the pattern is overwritten by received data. Just believing that the ethernet data is (should be) stored in the sdram area isn't enough.
    Debugging means that you have theories. Then you have to prove or disprove these theories one by one until you find the problem. The big problem is to separate what you believe and what you know, and prove that what you think really is true.
  • thanks for your answer...
    the received data from the ethernet are stored in the sdram. I wrote a small programm to see if I get the data here and yes the data overwrite my pattern. There's one ethernet register where I wrote the address for the received data from the ethernet (transmit to the sdram by dma)
    At the moment I have always data abort when data are received by the ethernet - and the address of the data abort is very often within the heap size.
    But I don't know why the heap size should be too small. I only read, that the stdio-lib would use a lot of heap size.
    my stack ptr is:
    __initial_sp                             0x00201018   Data         544  rm9200.o(STACK)
    and the stack top
    STACK                                    0x00200018   Section     4640  rm9200.o(STACK)
        Stack_Top                                0x00201238   Number         0  rm9200.o(STACK)
    the addr of the data abort is e.g.
    - 00203332
    - 00206572
    - 0020ACF5
    - 00206563
    always in the internal RAM:
    INT_RAM 0x200000 0x000FFFFF (.ANY(+RW +ZI))
    And moreover I know that the pointer to the USART will be overwritten very often - sometimes a data abort happens sometimes not. But this occured bevor data will be received.
  • If I try to write a pattern between the end of the internal sram and the stack top.
    ptr = (unsigned int *)0x00206500;
    If I received data packets by the ethernet, the pattern is nearly there. Sometimes I get a data abort, too, but not regularly when data are received from the ethernet; but I get nearly never a data abort, if no data will be received by the ethernet
    If the address is smaller (e.g. addr = 0x00204000) than I'm not able to run the programm. The programm always stays by PLLA_loop (wait until PLL A is stabilized)...
    Johannes
  • Is it correct, that the heap base addr is the same as the stack base addr?
    Execution Region INTERN_RAM (Base: 0x00200000, Size: 0x00001298, Max: 0x00040000, ABSOLUTE)
        0x00200000   0x0000000c   Data   RW           13    .data               init.o
        0x0020000c   0x00000004   Data   RW           45    .data               usart.o
        0x00200010   0x00000004   Data   RW           74    .data               retarget.o
        0x00200014   0x00000060   Zero   RW          169    .bss                libspace.o(c_t.l)
        0x00200074   0x00000004   PAD
        0x00200078   0x00000000   Zero   RW            2    HEAP                rm9200.o
        0x00200078   0x00001220   Zero   RW            1    STACK               rm9200.o
    Johannes
  • another thing which I don't understand is, that I changed the size of the internal RAM by the linker script.
    INTERN_RAM 0x200000 0x00040000
    And I still get a data abort with the address 0x002FFFB.
    Johannes
  • Changing the size of RAM in your configuration files will not change the physical memory in the processor,
    or how the memory controller in the processor handles exceptions.
    If you have a pointer (or return address) that points to a specific address, the processor will try to jump there without the slightest knowledge of the existence of memory.
  • that means, that the beginning of the heap will not change if I reduce the size of the internal RAM.
    How can I find out from which code / function the data abort will caused? At the moment I only know the address of the data abort.
    Johannes
  • What could be the problem if I write a pattern to the addr 0x00205241
    for(i=0; i<100; i++)
                    *ptr2=0xFF7;
                    *ptr2++;
    (the stack top is 0x00200798) and I'm not able to transmit any data by the usart? I always get a data abort (independent if there are ethernet packets).
    Johannes
  • If I only write:
       ptr2 = (unsigned int *)0x00205241;
            *ptr2=0xFF7;
    then I get a data abort to this address (caused by this write access)
    But why could that be a problem, the end of the internal RAM is 0x002FFFFF
    Johannes
