Hi all,
I am in the mass production stage and would like to write a software to do flash programming on my ARM7 chip. My current way is do programming by clicking the "Download" icon in Keil. My programming is done via ULINK USB - JTAG Adapter. Is there any way that I can develop my software in VB or VC++ to prigram HEX or BIN to the flash.
I counld not identify the library and help file regarding this. Anyone have experience please give hint.
Thank you.
"Is there any way that I can develop my software in VB or VC++ to prigram HEX or BIN to the flash."
See this appnote. "ULINK: USING ULINK AS A DEVICE PROGRAMMER" on KEIL http://www.keil.com/support/docs/3061.htm
The points are, - uLINK(2) handling is integrated just in uVision, no independent app just for FLASH programming. - uVision accepts command line (BATCH) mode to invoke the FLASH programming procedure. - No limit of the code size on HEX file, even on Demo/Evaluation version of uVision.
Execute the command line using ShellExecute()
"ShellExecute Function" on MSDN msdn2.microsoft.com/.../ms647732.aspx
Tsuneo
Remember that uLink is designed as a test/debug tool; For a production tool, perhaps you should be seeking something specifically designed for that?
http://www.jtag.com
http://www.xjtag.com
etc...
Thanks for the information. It is very useful !!
