Hi there!
I need some help with DPP (I think so).
code:
... mov r0, # _setP0 ; some below _setP0: scxt SYSCON, # 4C0h ...
after compiling and linking label was placed into adress 0x44C2 (in .M66 file and in disassembler). When I step over MOV command - in R0 was written 0x04C2 value, not 0x44C2. In disassembler I can see
00004482 E6F0C204 MOV R0,#0x04C2
Why MM part of code is C2 04, not C2 44?
As I can understand - 0x44C2 placed into 1st memory page and must be accessed via DPP1. I filled DPP1 with 0x1 which gives 1st page from 0x4000 + concatenated 14bit address = 4000 + 4C2 = 44C2.
Some info: Infenion 166 Memory model - small, Rom - 0x0 - 0x10000 Ram - 0x20000 - 0x40000 Rtx-166 tiny Reserve: 08h-0Bh,0ACh-0AFh,3000h-0031B8h,3200h-004428h
Any ideas?
Perhaps you could show the _setP0 entry in your map file? From your code...
The opcode for that memory location correctly states 0x04C2 as shown in your memory snippet.
Hi Chris!
in .m66 file:
0044C2H SYMBOL LABEL --- --- _setP0
In disassembler:
89: mov r0, # _setP0 00004482 E6F0C204 MOV R0,#0x04C2
What does it mean?
I am not sure what problem you have as this is not the output I get. So I tried your example and my map file matches the code. I would suggest you contact Keil support...
00012CH _setP0 LABEL --- NCODE MY_SECTION
In the disassembler
00000126 E6F02C01 MOV R0,#0x012C
So in my case I have the same memory located as the map file shows (both show the address 0x012C, the C166 is little endian so the bytes are flipped in memory).
So I don't know how to help you.
HI again Chris! Thanks for trying.
You got the SAME address because of your project is very SMALL (may be only one function in one c-file). I have the BIG project (6 files) and this function processed in the end of compiling.
If i put this function in beginning of main c-file - it works as your sample (2 address are same), but i want to make my project more reasonable separated in files. It is not error in KEIL, so I don't want to contact to support. I just want to understand where I am wrong in my opinion about compiler\linker working.
So, CAN ANYBODY ELSE SAY SOMETHING ABOUT THIS CASE?
PS: thanks Chris for trying once more
Any warnings from the linker?
DPP1 is used for accessing near constants (NCONST). The label _setP0 is not a near constant.
Try:
mov r0,#SOF _setP0
Are you aware that r0 is the user stack pointer and you must not change it?
Sauli
Hi Sauli !
There are no any warnings.
Try: mov r0,#SOF _setP0
Yes, it's really works:
90: mov r0,#SOF _setP0 91: 00004482 E6F0C244 MOV R0,#0x44C2
Thanks. I didn't know anything about PEC register loading before.
