Here is what I am trying to do: Send Hello World out the serial port of the AT91EB55 Evaluation Board
Here is what I have: I purchased the MDK-ARM kit and the AT91EB55 Evaluation Board. And ULINK2 to download programs to external flash
I now wish I would have purchased the phytec board instead because all of the example programs are for this board.
Has anyone used the AT91EB55 board with this tool suite. I noticed this board is on the Keil Device database. So it should be fully supported just as the Phytec board. So where are all the example programs for the AT91EB55?
What modifications to the target settings in the phytec hello world project would need to be made for the hello world project to work on the AT91EB55 board.
Thanks,
Jason
No one must be using the AT91EB55 evaluation board with the Keil Tools.
On the Atmel website these tools are the ones that are listed for this evaluation board:
Green hills 3.6.1 Multi® 2000 Software Tool
ARM® ADS 1.2 Software Tool
I am attempting to download to flash the phytec blinky project using ULINK2 to an AT91EB55 evaluation board.
It programs then verifys and then the uVision program exits.
I then go to open uVision back up and the last project loads as expected but all of the target settings have been removed. What would cause uVision to just exit with no warning or error?
A list of all of the target settings to load a program on the AT91EB55 board would be very helpfull.
Below is the version of the software that I am using:
IDE-Version: µVision3 V3.50 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2007
Tool Version Numbers: Toolchain Path: C:\Keil\ARM\BIN30\ C Compiler: ARMCC.Exe V3.0.0.951 Assembler: ARMASM.Exe V3.0.0.951 Linker/Locator: ARMLINK.Exe V3.0.0.951 Librarian: ARMAR.Exe V3.0.0.951 Hex Converter: FROMELF.Exe V3.0.0.951 CPU DLL: SARM.DLL V3.04 Dialog DLL: DARMAT.DLL V1.04 Target DLL: BIN\UL2ARM.DLL V1.26 Dialog DLL: TARMAT.DLL V1.03
