STR750 periphals menu shows STR710's one when debugging with ulink
When using simulator for debugging with STR750, [Peripherals menu] shows right STR750's peripherals and they work correctly. But when using ULINK ARM debugger, it shows STR710's peripherals and they don't work for STR750.
I guess this problem is due to the Dialog DLL "TARMST.DLL" with "-pSTR750" option when debugging. "-pSTR750" option might not have an effect on "TARMST.DLL" and it works as STR710 not STR750. But when using "DARMST.DLL" of simulator, "-pSTR750" option has an effect on "DARMST.DLL" and it works for STR750
Why doesn't TARMST.DLL work for STR750 but DARMST.DLL work well?
Please let me know the solution for the problem.
Jerry
IDE-Version:
uVision3 V3.51
Tool Version Numbers:
Toolchain Path: D:\ARM\Keil\ARM\BIN30\
C Compiler: ARMCC.Exe V3.0.0.951
Assembler: ARMASM.Exe V3.0.0.951
Linker/Locator: ARMLINK.Exe V3.0.0.951
Librarian: ARMAR.Exe V3.0.0.951
Hex Converter: FROMELF.Exe V3.0.0.951
CPU DLL: SARM.DLL V3.05
Dialog DLL: DARMST.DLL V1.05b
Target DLL: BIN\UL2CM3.DLL V1.06
Dialog DLL: TARMST.DLL V1.04i
  • The STR750 is an extremely new device. We have just finished the simulation/target dll's for that. They will be part of the next release.
    If you need them sooner, send an email with your contact information to support.intl@keil.com and refer to this forum thread.
  • Hello Reinhard,
    Thanks for your quick reply.
    I need the simulation & target dlls for STR750 at the moment. Could you send me them on behalf of support.intl@keil.com? I need them as soon as possible for doing the new project with STR750 on KEIL MDK environment.
  • Hello Reinhard,
    I am also working on the STR75x device and notice this problem long time ago (in january) and have to move to IAR for specific project. Currently we are back to KEIL tools. I am running the latest MDK release (mdk3.05a) and the peripherals still not matches the actual device (invalid names, values, missing TB timer, shows TIM{3:0}, where STR750 has only 2 TIM timers etc.).
    Can you please send me the updated dll's we need those dll to test the KEIL RTOS with ULINK2 ASAP.
    thanks!
