Hi all,
I am unsure how to write to the external eeprom on the nrf24e1 eval-board. the eeprom is that of 25xx320 (4kb), i would like to be able to receive 18bytes through the on-board UART Rx pin 0.1 then save this data to the external eeprom for later wireless transmission. I have so far only found assembler language examples, something i am unfarmiliar with to say the least. i have set-up the baud rate etc and believe i could receive the data now to the UART, but how would i in c-code take this data and save in the 25xx320?
Hope ive been clear enough,
and thank you!
phil
Surely, the 25xx320 Datasheet will tell you what to do?
You will also need to consult the eval-board Documentation to see how it's connected.
So what's wrong with this, on the Nordic site:
Software example: eewrite_v1_0.zip (size: 9 kb) "This example shows how to read and write the SPI eeprom connected to the nRF9E5 and nRF24E1 devices."
