gnu startup file for at91rm9200
I have another question about the AT91RM9200... I want to configurate the startup file to be able to use the gnu compiler.
Therefore I took a look into the startup file for one gnu example - there is no definition of the heap - is that correct?
What are the differences between the startup files (using gnu or using realview compiler)? Is it correct to change only the order by the configuration of the PIO controller and the mode bits?
.equ        Mode_USR               0x10
Where do I have to configurate the memory configuration in the gnu mode? When I use realview I can easily configurate the addresses where the internal / external ram /rom is - how is that possible with the gnu compiler? Because there's no such a field under "options for target" -> target?
best regards
Johannes
  • so now I have only 50 errors - not 400 erros at the start
    1.error: bad instruction 'preserve8'
    ;// <e> Instruction Cache Enable
    ;// </e>
            .equ    CACHE_SETUP,          1
                    PRESERVE8
    Should I delete this part of code - I didn't find the instruction cache in the other startup script.
    2. error bad instruction area, RESET, CODE
    #  Startup Code must be linked first at Address at which it expects to run.
                    AREA    RESET, CODE, READONLY
                    ARM
    _startup:
    Is it correct to use here
    # Starupt Code must be linked first at Address at which it expects to run.
            .text
            .arm
            .global _startup
            .func   _startup
    _startup:
    3. error bad instruction export reset handler
    # Reset Handler
                    EXPORT  Reset_Handler
    Reset_Handler
    Should I delete this part of the startup script to use it with the gnu compiler?
    Moreover I have several errors in the part of the "setup external bus interface (EBI)", "setup power management controller" - I don't want to post everything - maybe anybody could tell what I've to do with this part of startup script.
    best regards
    Johannes
  • now I try to load code to my at91rm9200 controller - but I get a error message
    "no algorithm found for: 00008000H - 0000AB6FH"
    "Erase skipped!"
    Under Options for Target->Utilities->Settings I changed nothing, because it works with the realview compiler... And when I changed the programming algorithm then I got the same error message.
    Could there be something wrong with the staartup file, I created for the GNU compiler?
    best regards
    Johannes
  • linking...
    /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/bin/ld: gnutest.elf: Not enough room for program headers, try linking with -N
    /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/bin/ld: final link failed: Bad value
    collect2: ld returned 1 exit status
    Target not created
    So I get new errors in the linker script; I use the one in the GNU folder from Keil and changed only the Memory Data and Memory Code...
    MEMORY
      CODE (rx) : ORIGIN = 0x10000000, LENGTH = 0x00FFFFFF             /* external flash */
      DATA (rw) : ORIGIN = 0x00000000, LENGTH = 0x000FFFFF             /* internal SRAM */
    The only think I found in the www is that, there could be a problem with the SIZEOF parameter in the linker script - but I don't find such parameter
    Johannes
  • now I'm able to write code to my controller - but the code don't work...
    there must be errors in the startup file I created for the GNU compiler. When I run in debug mode, I see only many assembler codes (no comments as it is when I work with the realview compiler)
    the last line is: 0x00200000 EAFFFFFE DD 0xEAFFFFE
    after this line nothing happens...
    Is there anybody who works with this AT91RM9200 controller and with the gnu compiler?
    Johannes
  • here is the part of the startup file, where the error must be.
    ;// <e> External Bus Interface (EBI)
            .equ    EBI_SETUP,            1
            .equ    SMC_CSR0_SETUP,       0x00000001
            .equ    SMC_CSR0_Val,         0x00003284
            .equ    SMC_CSR1_SETUP,       0x00000000
            .equ    SMC_CSR1_Val,         0x00000000
            .equ    SMC_CSR2_SETUP,       0x00000000
            .equ    SMC_CSR2_Val,         0x00000000
            .equ    SMC_CSR3_SETUP,       0x00000000
            .equ    SMC_CSR3_Val,         0x00000000
            .equ    SMC_CSR4_SETUP,       0x00000000
            .equ    SMC_CSR4_Val,         0x00000000
            .equ    SMC_CSR5_SETUP,       0x00000000
            .equ    SMC_CSR5_Val,         0x00000000
            .equ    SMC_CSR6_SETUP,       0x00000000
            .equ    SMC_CSR6_Val,         0x00000000
            .equ    SMC_CSR7_SETUP,       0x00000000
            .equ    SMC_CSR7_Val,         0x00000000
            .equ    EBI_CFG_SETUP,        0x00000001
            .equ    EBI_CSA_Val,          0x00000002
            .equ    EBI_CFGR_Val,         0x00000000
    ;//   <e> SDRAM Controller (SDRAMC)
            .equ    SDRAMC_SETUP,         1
            .equ    SDRAMC_MR_Val,        0x00000000
            .equ    SDRAMC_TR_Val,        0x000002E0
            .equ    SDRAMC_CR_Val,        0x2188C155
            .equ    SDRAMC_SRR_Val,       0x00001955
            .equ    SDRAMC_IER_Val,       0x00000000
            .equ    BFC_SETUP,            0
            .equ    BFC_MR_Val,           0x00000000
    # Power Management Controller (PMC) definitions
            .equ    PMC_BASE,             0xFFFFFC00      /* PMC Base Address       */
            .equ    PMC_SCER_OFS,         0x00            /* Sys Clk Enable Reg      Address Offset  */
            .equ    PMC_SCDR_OFS,         0x04            /* Sys Clk Disable Reg     Address Offset  */
            .equ    PMC_SCSR_OFS,         0x08            /* Sys Clk Status Reg      Address Offset  */
            .equ    PMC_PCER_OFS,         0x10            /* Periph Clk Enable Reg   Address Offset  */
            .equ    PMC_PCDR_OFS,         0x14            /* Periph Clk Disable Reg  Address Offset  */
            .equ    PMC_PCSR_OFS,         0x18            /* Periph Clk Status Reg   Address Offset  */
            .equ    CKGR_MOR_OFS,         0x20            /* Main Oscillator Reg     Address Offset  */
            .equ    CKGR_MCFR_OFS,        0x24            /* Main Clock Freq Reg     Address Offset  */
            .equ    CKGR_PLLAR_OFS,       0x28            /* PLLA Reg                Address Offset  */
            .equ    CKGR_PLLBR_OFS,       0x2C            /* PLLA Reg                Address Offset  */
            .equ    PMC_MCKR_OFS,         0x30            /* Master Clock Reg        Address Offset  */
            .equ    PMC_PCK0_OFS,         0x40            /* Programmable Clk 0 Reg  Address Offset  */
            .equ    PMC_PCK1_OFS,         0x44            /* Programmable Clk 1 Reg  Address Offset  */
            .equ    PMC_PCK2_OFS,        0x48            /* Programmable Clk 2 Reg  Address Offset   */
            .equ    PMC_PCK3_OFS,         0x4C            /* Programmable Clk 3 Reg  Address Offset  */
            .equ    PMC_IER_OFS,          0x60            /* Interrupt Enable  Reg   Address Offset  */
            .equ    PMC_IDR_OFS,          0x64            /* Interrupt Disable Reg   Address Offset  */
            .equ    PMC_SR_OFS,           0x68            /* Status Reg              Address Offset  */
            .equ    PMC_IMR_OFS,          0x6C            /* Interrupt Mask Reg      Address Offset  */
    ; Bit constants
            .equ    PMC_MOSCEN,           (1<<0)          /* Main Oscillator Enable   */
            .equ    PMC_MUL,              (0x7FF<<16)     /* PLL Multiplier                   */
            .equ    PMC_MOSCS,           (1<<0)          /* Main Oscillator Stable    */
            .equ    PMC_LOCKA,            (1<<1)          /* PLL A Lock Status                */
            .equ    PMC_LOCKB,           (1<<2)          /* PLL A Lock Status         */
            .equ    PMC_MCKRDY,           (1<<3)          /* Master Clock Status      */
            .equ    PMC_SETUP,            1
            .equ    PMC_SCER_Val,         0x00000001
            .equ    PMC_PCER_Val,         0x00000018
            .equ    CKGR_MOR_Val,         0x0000FF01
            .equ    CKGR_PLLAR_Val,       0x2026BF04
            .equ    CKGR_PLLBR_Val,       0x10483F0E
            .equ    PMC_MCKR_Val,         0x00000202
            .equ    PMC_PCK0_Val,         0x00000000
            .equ    PMC_PCK1_Val,         0x00000000
            .equ    PMC_PCK2_Val,         0x00000000
            .equ    PMC_PCK3_Val,         0x00000000
    ; Area Definition and Entry Point
            .text
            .arm
            .global _startup
            .func   _startup
    _startup:
    # Exception Vectors
    #  Mapped to Address 0.
    #  Absolute addressing mode must be used.
    #  Dummy Handlers are implemented as infinite loops which can be modified.
    Vectors:        LDR     PC,Reset_Addr
                    LDR     PC,Undef_Addr
                    LDR     PC,SWI_Addr
                    LDR     PC,PAbt_Addr
                    LDR     PC,DAbt_Addr
                    NOP                     /* Reserved Vector */
    #               LDR     PC, IRQ_Addr
                    LDR     PC, [PC, #-0xF20]       /* Vector from AIC_IVR */
    #               LDR     PC, FIQ_Addr
                    LDR     PC, [PC, #-0xF20]       /* Vector from AIC_FVR */
    Reset_Addr:     .word   Soft_Reset
    Undef_Addr:     .word   Undef_Handler
    SWI_Addr:       .word   SWI_Handler
    PAbt_Addr:      .word   PAbt_Handler
    DAbt_Addr:      .word   DAbt_Handler
                    .word   0                       /* Reserved Address */
    IRQ_Addr:       .word   IRQ_Handler
    FIQ_Addr:       .word   FIQ_Handler
    Soft_Reset:     B       Soft_Reset
    Undef_Handler:  B       Undef_Handler
    SWI_Handler:    B       SWI_Handler
    PAbt_Handler:   B       PAbt_Handler
    DAbt_Handler:   B       DAbt_Handler
    IRQ_Handler:    B       IRQ_Handler
    FIQ_Handler:    B       FIQ_Handler
    # Reset Handler
    Reset_Handler:
  • second part
    .if PMC_SETUP
    # Setup System Clock
                    LDR     R0, =PMC_BASE
                 /*   ; System Clock Enable  */
                    LDR     R1, =PMC_SCER_Val
                    STR     R1, [R0, #PMC_SCER_OFS]
                /*    ; Peripheral Clock Enable     */
                    LDR     R1, =PMC_PCER_Val
                    STR     R1, [R0, #PMC_PCER_OFS]
    .if CKGR_MOR_Val & PMC_MOSCEN
                  /*  ; Setup Main Oscillator */
                    LDR     R1, =CKGR_MOR_Val
                    STR     R1, [R0, #CKGR_MOR_OFS]
                  /*  ; Wait until Main Oscillator is stabilized   */
    MOSCS_Loop:     LDR     R2, [R0, #PMC_SR_OFS]
                    ANDS    R2, R2, #PMC_MOSCS
                    BEQ     MOSCS_Loop
    .endif
     .if CKGR_PLLAR_Val & PMC_MUL
                   /* ; Setup the PLL A      */
                 /*   IF      (CKGR_PLLAR_Val:AND:PMC_MUL) != 0   */
                    LDR     R1, =CKGR_PLLAR_Val
                    STR     R1, [R0, #CKGR_PLLAR_OFS]
                   /* ; Wait until PLL A is stabilized */
    PLLA_Loop:      LDR     R2, [R0, #PMC_SR_OFS]
                    ANDS    R2, R2, #PMC_LOCKA
                    BEQ     PLLA_Loop
    .endif
    .if CKGR_PLLBR_Val & PMC_MUL
                  /*  ; Setup the PLL B     */
                /*    IF      (CKGR_PLLBR_Val:AND:PMC_MUL) != 0  */
                    LDR     R1, =CKGR_PLLBR_Val
                    STR     R1, [R0, #CKGR_PLLBR_OFS]
                  /*  ; Wait until PLL B is stabilized       */
    PLLB_Loop:      LDR     R2, [R0, #PMC_SR_OFS]
                    ANDS    R2, R2, #PMC_LOCKB
                    BEQ     PLLB_Loop
    .endif
                 /*   ; Setup the Master Clock and the Processor Clock      */
                    LDR     R1, =PMC_MCKR_Val
                    STR     R1, [R0, #PMC_MCKR_OFS]
                 /*   ; Wait until Main Master Clock is ready */
    MCKR_Loop:      LDR     R2, [R0, #PMC_SR_OFS]
                    ANDS    R2, R2, #PMC_MCKRDY
                    BEQ     MCKR_Loop
                  /*  ; Setup Programmable Clock Register 0 */
                    LDR     R1, =PMC_PCK0_Val
                    STR     R1, [R0, #PMC_PCK0_OFS]
                 /*   ; Setup Programmable Clock Register 1 */
                    LDR     R1, =PMC_PCK1_Val
                    STR     R1, [R0, #PMC_PCK1_OFS]
               /*     ; Setup Programmable Clock Register 2   */
                    LDR     R1, =PMC_PCK2_Val
                    STR     R1, [R0, #PMC_PCK2_OFS]
              /*      ; Setup Programmable Clock Register 3    */
                    LDR     R1, =PMC_PCK3_Val
                    STR     R1, [R0, #PMC_PCK3_OFS]
    .endif
    # Copy Exception Vectors to Internal RAM
                                 SUB     R8, PC, #.-Vectors+8
                    .ifdef   REMAPPED
                     MOV     R9, #RAM_Base
                    .else
                     MOV     R9, #RAM_Base_Boot
                    .endif
                   /* IF      :DEF:RAM_INTVEC */
                  /*  ADR     R8, Vectors     ; Source       */
                   /* LDR     R9, =RAM_BASE   ; Destination */
                    LDMIA   R8!, {R0-R7}    /*; Load Vectors   */
                    STMIA   R9!, {R0-R7}    /*; Store Vectors       */
                    LDMIA   R8!, {R0-R7}    /*; Load Handler Addresses */
                    STMIA   R9!, {R0-R7}    /*; Store Handler Addresses      */
                   /* ENDIF */
    ; Remap on-chip RAM to address 0
                    IF      :DEF:REMAP
                    LDR     R0, =MC_BASE
                    MOV     R1, #1
                    STR     R1, [R0, #MC_RCR_OFS]   ; Remap
                    ENDIF
    # Initialise EBI and execute Remap
                    LDR     R12, AfterRemapAdr      /* Get the Real Jump Address */
                    ADD     R11, PC, #EBI_Table-.-8
                    LDMIA   R11, {R0-R10}           /* Load EBI Data */
                    STMIA   R10, {R0-R9}            /* Store EBI Data with Remap */
                    MOV     PC, R12                 /* Jump and flush Pipeline */
    AfterRemapAdr:  .word   AfterRemap
    AfterRemap:
    # Initialise Interrupt System
    best regards
    Johannes
