UART is repeating at output what it receives
I have a 89C5131 talking to a RS-232 device, 50 cm from the chip. Using Max232 in standard configuration and RX/TX/GND cable.
The task is to send assincronous commands to the device and read its response and ping pong the configuration.(the device timeout is 3 seconds).
Problem: For some reason (what I am asking you for help), the micro repeats - sometimes - whatever have been received at its input. Like, the micro repeats to the device the string just received. Of course the device them does not recognize it as a valid string and timeout or halts.
I use the INTSIO2 example from Keil and the following program to write and read the commands.
the code - it is sio.c with the mods below:
void com_baudrate ()
Clear transmit interrupt and buffer.
TI = 0;             /* clear transmit interrupt */
t_in = 0;           /* empty transmit buffer */
t_out = 0;
Set timer 2 up as a baud rate generator.
 Set_timer2_x1_mode();
  SCON = 0xF0; /* uart in mode 3 (9 bit), REN=1 */
   T2CON &= 0xF0;               /* EXEN2=0; TR2=0; C/T2#=0; CP/RL2#=0; */
   T2CON |= 0x30;               /* RCLK = 1; TCLK=1; */
   TH2=0xFF;                    /* init value */
   TL2=0xFD;                    /* init value */
   RCAP2H=0xFF;                 /* reload value, 9600 Bds at 16MHz */
   RCAP2L=0xCC;                 /* reload value, 9600 Bds at 16MHz */
        ES = 1;                                                      /* Enable serial interrupt */
        EA = 1;                                              /* Enable global interrupt */
   TR2 = 1;                     /* Timer 2 run */
The above is for 9600, 8, 1, even.
static void com_isr (void) interrupt 4
Received data interrupt.
if (RI != 0)
  RI = 0;
  if (((r_in - r_out) & ~(RBUF_SIZE-1)) == 0)
    rbuf [r_in & (RBUF_SIZE-1)] = SBUF;
    r_in++;
Transmitted data interrupt.
if (TI != 0)
  TI = 0;
  if (t_in != t_out)
        ACC = (tbuf [t_out & (TBUF_SIZE-1)]);
        TB8 = P;
        SBUF = (tbuf [t_out & (TBUF_SIZE-1)]);
    t_out++;
    ti_restart = 0;
  else
    ti_restart = 1;
This is for transmission with the even bit.
void get_serial_cmd()
unsigned char buff;
int counter;
        while ((buff !=0xFC) && (buff !=0))
        buff = getchar();
        if (buff==0xFC)
                serial_read[0] = 0xFC;
                serial_read[1] = getchar();
                for (counter = 2; counter < (serial_read[1]); counter++)
                serial_read[counter] = getchar();
int send_serial_cmd(unsigned char serial_cmd[16])
int counter;
print_to_lcd = 0;       //Diverts putchar to UART
for (counter = 0; counter<serial_cmd[1]; counter++)
        putchar(serial_cmd[counter]);
print_to_lcd = 0;       //Diverts putchar to LCD
return (0);
The above receives and sends the strings from the device.
The program calls this function as:
void action_bill_accepted()
        if (serial_read[2] == 0x15)
                send_serial_cmd(ACKNOWLEDGE);
                get_serial_cmd();
        if (serial_read[2] == 0x16)
                send_serial_cmd(STATUS_REQUEST);
                get_serial_cmd();
_getkey and putchar are below:
char _getkey (void)
int k;
do
    k = com_getchar();
while (k == -1);
return ((unsigned char) k);
char putchar (char c)
        volatile unsigned int i;
        if (print_to_lcd == 1)
                lcd_putchar(c);
        if (print_to_lcd == 0)
        while (com_putchar (c) != 0)
                for (i=0; i<1000; i++)
                //*** DO NOTHING **
return(c);
Any suggestion is welcome.
Ed
