C16x, monitor, interrupts
Hi all,
Quick question: we're looking into using the monitor for simple debugging tasks. What happens when the monitor sets a breakpoint on main()? Are all interrupts stopped as well? And when you single step one code line, are interrupts only enbled for that period of time?
Helloworld is working fine, we're now trying to get our main app to work. Single stepping works but our screen seems to be turned off and we're wondering if it has something to do with the interrupts in combination with the monitor.
Regards,
Joost Leeuwesteijn
  • Turned out some code was still trying to use the serial port, which is a big no-no. The application starts when I press F5/run. The remaining problem is that the Halt button doesn't work. I expected to end up somewhere in the code, where execution is stopped.
    Does anyone have a clue what could prevent the Halt to work?
    In the meantime I'll (re)read some more manual :-)
    Regards,
    Joost Leeuwesteijn
  • I'll just add some findings, in case somebody finds this thread useful.
    The "halt software on..." radio button (in the debugging options) was set to "NMI only". I switched it to "Serial and NMI" but it had no effect. I did work once, maybe it depends on when you press the Halt button.
    Breakpoints are working, but a breakpoint in a piece of code that is only executed when some keys are pressed caused a crash. Still looking into that.
    Joost
