Dear Sir,
This is Thillai Elayaraja S from SCOLIS Technologies (India) Pvt. Ltd., Chennai, INDIA. We are into the development of Timer APIs for the Agere's USS2828 Full Speed USB Chip with its ARM7TDMI Core. We are wondering that though we were proper in all the clock configurations (CLKRST Module) and in the Interrupt Configurations (PIC Module) we were not able to get an Interrupt while the Down Counter of the Timer module reaches Zero. Hereby we have attached the codes for your kind reference. Please check it up and guide us where we went wrong. We apologize for the wrong code, if any…
With Anticipation, Thillai Elayaraja S
// // C Code //
// Timer Initialisation module
void TimerHalInit (void) {
// Enable Clock for Timer Block
CLKRSTGATE &= ~CLKRSTGATE_TIMERCLK_;
// Reset the control bits of Timer1 and Timer2
TIMER1CTL = 0x0;
// Initialize Timer1 to its Load Value
TIMER1BGL = (TIMER_LOAD_VALUE ((WORD) 1)); TIMER1LOAD = (TIMER_LOAD_VALUE ((WORD) 1));
// Start Timer1 in 32 Bit, Prescale0, Interrupt/Timer Enable & in Periodic mode
TIMER1CTL |= (TIMERCTL_32BITTIMER_ | TIMERCTL_PRESCALE0__ | TIMERCTL_INTEN_ | TIMERCTL_PERIODICMODE_ | TIMERCTL_TIMEREN_);
// Enable Timer1 Interrupts in Interrupt Controller Module
PICINTEN |= PICIRQ_TIMER1_;
// Clear the I Bit of the CPSR register
ArmHalEnableInterrupt (); }
// Timer Interrupt module
__irq void arm_irq_exception (void) {
// Just Turns on a LED connected to a GPIO for indicating that an Interrupt occured
LedManTurnOn (0x01); }
// startup.s
; .. ; Stack Initialisations ; ..
AREA Reset, CODE, READONLY, ALIGN=2
B Reset_Handler ; on reset go to code in ROM B uss2828_soft_reset B uss2828_soft_reset B uss2828_soft_reset B uss2828_soft_reset NOP ; Reserved vector IMPORT arm_irq_exception PRESERVE8
B arm_irq_exception B uss2828_soft_reset
DCI 0x12345678
IMPORT uss2828_soft_reset
EXPORT Reset_Handler
Reset_Handler
NOP NOP NOP NOP NOP
; .. ; Stack and Memory Pointer Configurations ; ..
BL __main
EXPORT AsmJmpToFuncFirmware ; Location where the Functional Firmware resides
START_FNCFW EQU 0x20010000 START_FNCFW_EXTMODE EQU 0x00010000 START_FNCFW_CLFPGA EQU 0x00005000
SUB SP, SP, #0x100 MOV PC, R12 END
