bad optimization with Rn=0;
#include <AT892051.H>
#pragma OPTIMIZE (9, SPEED)
void main (void)
{ unsigned char R;
        R=0;  // this statement always produces ASM-code:
          // CLR  A
          // MOV  R7,A
          // ...!!!!.... why not MOV R7,#0   (2 bytes 1 cycle instead of 2 bytes and 2 cycles)
          //  but, if R=5;   is produced code: MOV  R7,#05H  ;;;;;;;  :o)
   if(P1==0x55) R++;
  • What further assembly code follows ?
    Maybe the code would need to clear A anyway.
  • Hi Christoph !
    NO , always :O))
    See full example:
    void main (void)
    { unsigned char R;
    R=0;  // this statement always produces ASM-code:CLR  A;   MOV  R7,A;
    ACC=2;
    if(P1==0x55) R++;
    ASSEMBLY LISTING OF GENERATED OBJECT CODE
                 ; FUNCTION main (BEGIN)
                                               ; SOURCE LINE # 4
                                               ; SOURCE LINE # 5
                                               ; SOURCE LINE # 6
    ;---- Variable 'R' assigned to Register 'R7' ----
    0000 E4                CLR     A
    0001 FF                MOV     R7,A
                                               ; SOURCE LINE # 7
    0002 7402              MOV     A,#02H
                                               ; SOURCE LINE # 8
    0004 E590              MOV     A,P1
    0006 B45501            CJNE    A,#055H,?C0002
    0009 0F                INC     R7
                                               ; SOURCE LINE # 9
    000A         ?C0002:
    000A 22                RET
  • I do not think anyone (at least not in this forum) will argue that Keil makes the best toolset for the '51.
    However, the constant "move everything through the accumulator" is, indeed a place where the Keil compiler could use some improvement. This improvement, however should not be an optimixztion, but a compiler improvement. One of my basic beefs with the Keil tools is that some things that should be done (and probably could be implemeted better) by the compiler (e.g. switch) are done by the optimizer.
  • "... things that should be done [...] by the compiler [...] are done by the optimizer"
    I have the same feeling. Another simple example: downcounting loops are not collapsed into DJNZ unless you turn optimizations ON.
    Several of the low-level generic functions on my libraries are implemented directly in assembly and prototyped to be called from C, to avoid the compiler lazy translation overhead.
  • MOV R7,#0
    executes in 2 cycles and takes 2 bytes
    CLR A
    MOV  R7,A
    also executes in 2 cycles and takes 2 bytes. However many times there is a another value 0 required a bit later. I agree that the optimization is a bit random, but in general it is better.
  • Excuse me, but you are mistaken.
    MOV Rn,#data
        bytes 2
        Cycles 1
    Look in the bible on MCS51. It's real .
